NZXT H440 Custom Loop?
Go to solution Solved by TheHiddenCreeper,
YES IT CAN SLOVED
So I'm going to purchase the Nzxt H440 will it support a full custom loop which will only be the cpu in the loop no gpu :)  :)
Cpu: Intel i7-5820k at 4.6 Ghz // Motherboard: Asus X99 Pro // Ram: 32gb of Crucial Balistix at 2400 Mhz // Gpu: GTX 1080 Founders Edtion // SSD: Samsung 850 evo 250gb, Samsung 950 pro 256 gb, // Cooler: Cooler Master ml240r // Case: NZXT h500i
https://linustechtips.com/topic/364855-nzxt-h440-custom-loop/
YES IT CAN SLOVED
https://linustechtips.com/topic/364855-nzxt-h440-custom-loop/#findComment-4942568
Will it support custom loop? Yes.
Custom loop is about "Making it work" with bonus points for making it work well and making it look good. The windows isn't the best on the H440 and the space is eaten up by the drive bays but other than that it looks good. There are better options in my opinion but at the end of the day it's an aesthetic choice but also one that makes the overall process easier (by going with a more suited case) the new Fractal Design Define S is actually a very good alternative if you're looking for custom-loop. It has a massive window and mountings for your res as well as being designed for custom loop water cooling in mind.
HydrOS (Waterworks 3.0) Pictures: // One // Two // Three
i7 5820k @ 4.3GHz (1.165v) // Asus X99-A // 16GB-DDR4 Vengeance 2400 CAS13 // RAID 0 Intel 730 240GB // Nvidia Titan X (+200Core +500Memory) // Swiftech D5 // ASUS ROG SWIFT
https://linustechtips.com/topic/364855-nzxt-h440-custom-loop/#findComment-4942574
Thank you for the help
https://linustechtips.com/topic/364855-nzxt-h440-custom-loop/#findComment-4942657
