Not overclocking
Go to solution Solved by OleXavi,
You need to provide more info than that. Telling us what GPU you have would be a good start
Zotac 960 AMP! Edition with an MSI Z87 MPOWER
Hello!!!
I just started overclocking my GPU, and i tested it in FurMark where the temperatures where fine and it didn't crash.
Then when i turned my computer on again, the system said that the overclock didn't work and it reset to its normal values.
Is there an option or anything that i havee to turn on, or what should i do???
Using MSI Afterburner
Thx for any answers :))
CPU: i5 4690K  GPU: Zotac 960 AMP! Edition  Case: Corsair Obsidian 450D  Power Supply: CM V550  RAM: Kinston 8GB 1866Hz  Cooling: CM Nepton 240M  MOBO: MSI Z87 MPOWER                                                         Im addicted to PC.... Help me
https://linustechtips.com/topic/364683-not-overclocking/
https://linustechtips.com/topic/364683-not-overclocking/#findComment-4940679
