so i have an old x58 mobo that's chipset overheats with its i7 920 is there a way to remove the chipset heatsink and make it cooler?
here is my mobo
http://support.hp.com/us-en/document/c01901210
Cpu: Intel i7-5820k at 4.6 Ghz // Motherboard: Asus X99 Pro // Ram: 32gb of Crucial Balistix at 2400 Mhz // Gpu: GTX 1080 Founders Edtion // SSD: Samsung 850 evo 250gb, Samsung 950 pro 256 gb, // Cooler: Cooler Master ml240r // Case: NZXT h500i
https://linustechtips.com/topic/364614-x58-overheating-problems/
Put a fan near it.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/364614-x58-overheating-problems/#findComment-4939685
tried dosnt help just a tad bit cooler
https://linustechtips.com/topic/364614-x58-overheating-problems/#findComment-4939703
here is my mobo
You posted this same question yesterday......
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/364614-x58-overheating-problems/#findComment-4939706
is there a way i can remove dried thermal pads to replace it
https://linustechtips.com/topic/364614-x58-overheating-problems/#findComment-4939709
i dont think so, you migght wanna look into addint a fon on top of th heatsink, like this one:
http://www.dx.com/p/jinli-4010-9-blade-brushless-cooling-fan-for-1-8-1-10-scale-brushless-esc-motor-black-5v-227292
Computer's don't make errors. What they do, they do on purpose.
https://linustechtips.com/topic/364614-x58-overheating-problems/#findComment-4939721
yes it was not answered fully
https://linustechtips.com/topic/364614-x58-overheating-problems/#findComment-4939729
Yes. Remove the thermal pad and replace it with some quality thermal paste. If needed after that you can mount a fan on or near the heatsink to help.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/364614-x58-overheating-problems/#findComment-4939865
