keyboard/mouse advice
i get quite bad hand ache from my mouse and keyboard. thinking about switching them up.
i currently have razer deathadder which i find way to big for my small hands and fingertip grip
my keyboard is a kbc poker 2 but i need the other keys.
i also have tried griffiti wrist rests and a gel mouse wrist rest.
still get ache
any ideas?
https://linustechtips.com/topic/364274-keyboardmouse-advice/
still get ache
any ideas?
If a Deathadder is painful with small hands and a fingertip grip you might want to use the PC a little less...
Try something like a Logitech G400s and see how that works.
https://linustechtips.com/topic/364274-keyboardmouse-advice/#findComment-4934741
i really dont use it that much. after 30 mins it hurts.
Get your wrist checked out by a doctor first man. The Deathadder should be comfy.
https://linustechtips.com/topic/364274-keyboardmouse-advice/#findComment-4934788
i feel like it would be if i used a palm grip but i have really small hands and it just doesnt work. i used to use one of these http://ecx.images-amazon.com/images/I/411yXU0t1wL._SY300_.jpg
lol
https://linustechtips.com/topic/364274-keyboardmouse-advice/#findComment-4934875
lol
Again, get your wrist checked by a wrist doctor or something first :P I like the shape of the Deathadder and I use fingertip mixed with claw grip all day. I also have small hands.
https://linustechtips.com/topic/364274-keyboardmouse-advice/#findComment-4934885
I use the K65 when I'm at LAN, and K95 when I'm at home. I find these amazing. Especially with the wrist rest.
For mouse, I use g502. I have noticed my fingers move a bit between palm and claw grips when I'm playing. And both of these grips are nice for me. I have medium hands (I think lol). But I would suggest you to try these, if you ever were to decide on either of the mentioned products.
I used to have a deathadder. I felt it was a bit weird to hold. My pinkie finger kept grazing against the mousepad (which is not too comfy in the longer sessions).
I just felt like giving you tips on what I moved from and to. Just in case you ever were to get to try either the k6/95 or the g502.
https://linustechtips.com/topic/364274-keyboardmouse-advice/#findComment-4936996
i think i may got to the k65 actually :) looks really nice too. originally considered it before i bought my poker 2
mouse wise i might go for a zowie as the hump of the mouse is low which i think is what makes the deathadder uncomfortable
https://linustechtips.com/topic/364274-keyboardmouse-advice/#findComment-4946416
