Greetings.
I have been on this site a little bit but had an issue with signing up, luckily my friend was able to ask and a mod helped get things sorted! I realize this question gets asked probably 200 times a week, and while they all have been answered I feel my specific situation is different enough to warrant asking.
I currently have a Gigabyte 7970 oc windforce 3x. I want to upgrade my monitor but currently with all the cool new tech around I'm really not comfortable buying just yet. I want to wait about a year maybe a bit longer for the whole freesync/Gsync tech too mature before buying into it. I am going to be looking at something like a 1440p 144hz ISP (only one exists right now I think, the rog gsync one). That said even at 1080p 60hz my 7970 is showing its age especially with the latest releases. GTA 5 made my poor old card its bitch.
I was thinking of just getting a new card but to get a real upgrade I am looking at 500 bucks were I live. Then I remembered that the 280X crossfires just fine with my 7970 as its just a re badge. That means i can do crossfire and get the extra performance I am looking for, for about 220 dollars less. Normally when looking to upgrade I would go new card every single time, this time I am not looking for my GPU solution to be rock solid for 2 to 3 years but instead only one. with Nvidia line up being 8 months old, I figure adding the second card with breath enough life into my system to make it too the next generation were I can get a new monitor and a better suiting GPU solution.
Appreciate any help.
Edit: I checked to make sure also, my PSU can more then handle a second card and my motherboard supports it.
https://linustechtips.com/topic/363938-help-second-card-or/
Wait a little while longer until AMD's new 3xx series come out ina month or two, more options+slight price drops.
My Gigabyte R9 280x is a fucking BOSS, really. It pulls off 1080p gaming on ultra without much fuss.
To summarize, wait for the 3xx series and pick a single GPU.
Mobo: Gigabyte 970A-DS3P CPU: AMD FX 8350 RAM: Kingston HyperX Fury DDR3 8gb (2x4gb@1600Mhz) GPU: Gigabyte R9 280x (factory oc) PSU: Thermaltake SmartSE 730w Case: Corsair 200R
Blog thingy <----
https://linustechtips.com/topic/363938-help-second-card-or/#findComment-4930360
one thing I find silly about these forumns is people always say wait. I don't think he wants to wait. I'd get the 280x since you said newer games are making your current GPU it's bitch.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/363938-help-second-card-or/#findComment-4930402
There's nothing to loose so why not wait a month?
Price drops and new cards are always nice when you are in the market for a new GPU, especially when they are right around the corner.
Blog thingy <----
https://linustechtips.com/topic/363938-help-second-card-or/#findComment-4930516
Thanks for the input, sorry I had work so couldn't reply. I will defiantly wait for a sale for a 280X if that is the way I go. However I may have worded the question poorly. I was wondering if its wise to buy a second card to boost performance for the 12 months I need it to wait out Gsync/freesync for more options or is a single card far superior. By the end of that 12 months not only should there be more Gsync/freesync monitors but also the new line of Nvidia.
While the current gen is amazing if I was to go with Gsync it seems crazy to buy cards suitable for my new monitor when it might be 12 months before I get it, I would rather buy something to give me enough performance until I buy the new screen and new graphics cards too.
https://linustechtips.com/topic/363938-help-second-card-or/#findComment-4934801
