i am thinking about o buy h100i.
i have heard from some people that it have leaking problem is it true?
[spoiler= Dream machine (There is also a buildlog)]
Case: Phanteks Enthoo Luxe - CPU: I7 5820k @4.4 ghz 1.225vcore - GPU: 2x Asus GTX 970 Strix edition - Mainboard: Asus X99-S - RAM: HyperX predator 4x4 2133 mhz - HDD: Seagate barracuda 2 TB 7200 rpm - SSD: Samsung 850 EVO 500 GB SSD - PSU: Corsair HX1000i - Case fans: 3x Noctua PPC 140mm - Radiator fans: 3x Noctua PPC 120 mm - CPU cooler: Fractal design Kelvin S36 together with Noctua PPCs - Keyboard: Corsair K70 RGB Cherry gaming keyboard - mouse: Steelseries sensei raw - Headset: Kingston HyperX Cloud Build Log
https://linustechtips.com/topic/36367-h100i-leakking-problem/
I've built two PCs with H100i loops when they were released and haven't heard any problems yet.  I haven't heard of other people having an H100i leak either.
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
https://linustechtips.com/topic/36367-h100i-leakking-problem/#findComment-466763
Of course it's true... but that's the 1 out of 100000000000000000000000 who owns and said it's leaking. You can find horror stories about any product but the thing is, the people who has problems with it will go online and say something about whereas others who have no problem (majority of people) will not say a thing.
https://linustechtips.com/topic/36367-h100i-leakking-problem/#findComment-466772
ok thx.. never in my life had any water system... dont know much about them..
https://linustechtips.com/topic/36367-h100i-leakking-problem/#findComment-466776
well if i buy h100i i will put it outside of the case for a fue days to see if it leaks. dont want expensive hardware to be wet
https://linustechtips.com/topic/36367-h100i-leakking-problem/#findComment-466782
If it leaks Corsair will cover your loss. There really isn't any need to do this.
https://linustechtips.com/topic/36367-h100i-leakking-problem/#findComment-466790
I couldnt see it leaking anytime soon, the tubes are like steel and you'll probably have to go at it with a knife to make a dent and then i doubt you will actually break the thing, dont use the fans it comes with tho, get yourself a couple of SP-120 quiet editions, there amazing, the loudest thing in my rig now is either my gpu or my psu :D
 Asus M5A99X Evo  - AMD FX-8350 - 16GB Corsair Vengeance 1866Mhz - Corsair 120mm Quiet Edition Fans BenQ XL2411Z- EVGA GTX 980 Superclocked Fractal Design Define R4 - Corsair H100i - 2 TB 7200rpm HDD - Samsung 840 Evo 120GB - Corsair RM750w PSU - Logitech G502 Proteus Core - Corsair K70 RGB MX Red - Audio Technica M50x + Modmic 4.0 - LG 23EA63V x2
Spinthat Spinthat Spinthat Spinthat
https://linustechtips.com/topic/36367-h100i-leakking-problem/#findComment-466830
