will it fit?
Go to solution Solved by ADZ_123_!"£,
Yes it does fit.
Yes it does fit.
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/363497-will-it-fit/#findComment-4924871
will the corsair h105 fit in to the termaltaker overseer rx-i
http://uk.pcpartpicker.com/part/corsair-cpu-cooler-cw9060016ww
http://uk.pcpartpicker.com/part/thermaltake-case-vn700m1w2n
and or if there is any other better cooler pls leave a comment
From what I can tell, yes.
BUT there's better coolers for the money then H105.
"Rawr XD"
https://linustechtips.com/topic/363497-will-it-fit/#findComment-4925564
