I managed to put a 4790K in my build without compromising any budget. The only downside is that I don't have an SSD in there anymore. I much prefer the 4790K, I will more than likely utilize all it's abilities, if I don't at least my parents will be satisfied that my computer is fast as f*ck.
Anyway, is there a problem with getting an SSD later and just putting OS on there? I've heard it can rewrite some paths and lose all your data.
BUILD: http://au.pcpartpicker.com/p/46PvFT
 My Buyer’s Guide!
Build:
CPU: Intel Core i5 4690K Cooler: Cryorig R1 Ultimate RAM: Kingston Fury White Series 8GB SSD: OCZ 100 ARC 240GB HDD: Seagate Barracuda 1TB Motherboard: MSI Z97S SLI Krait Edition Graphics Card: Powercolor PCS+ R9 390 Case: Phanteks Enthoo Pro (White) Power Supply: EVGA G2 750W Monitor: LG 29UM67-P 29" 21:9 Freesync Sexiness Mouse: Razer Deathadder ChromKeyboard: Razer Blackwidow 2014 Headset: Turtle Beach Ear Force XP400
https://linustechtips.com/topic/363264-any-problem-with-an-ssd-later/
Well you wouldn't want to copy paste the data to the SSD, you would reinstall the OS, and it would be fine.
If I reinstall it on the dofferent drive does that delete the original copy of the OS on the HDD?
 My Buyer’s Guide!
Build:
There is no problem.
I also have experience while I did my OC with many BSODs untill I found a stable one and all these crashes did nothing to my SSD nor the OS, or on the info on all my HDDs.
Btw I have doubts that small CM 212 would be able to handle the heat form the overclock as I see my Noctua NH-D14 struggle with keeping the heat under 85*C.
ASRock Z97 PRO 4| i7-4790К@4600MHz/1.26V| Noctua NH-D14| 16GB ADATA@1800Mhz| Gigabyte GTX 660 WF OC| Samsung 840 Pro 128GB; Samsung 860 Pro 256GB; Samsung 860 EVO 500GB| Seasonic SS-650KM3 Gold| CM Storm QuickFire Ultimate| Mionix Naos 7000|
