Graphics Issue
Go to solution Solved by ADZ_123_!"£,
He tested with another monitor and yet again the PC froze. :/
Has he tried doing an os reinstall. But before you do that then I would try seeing if the same problem when running of Intel integrated graphics.
Hi there,
I'm writing for a friend since he's PC is fucked up, yet we don't know what's going on, that's why we need help.
So yesterday his PC start frozzing all the time, he turned his PC on and 2 or 3 minutes after the PC freeze and didn't allow him to do anything. He tried to do a system restore but the PC went black screen and he had to turned it off cause he could do anything with it. Today the PC actually turned on no problem and was running fine for about 50 mins, passed that 50 mins the PC froze and went like this:
We don't know what's going on but we suspect that it's something related with the graphic card. His PC is kinda old but he brought this new graphic card like 3 months ago. We're looking forward to know what's going on so we can go to the store and replace the faulty part.
Thanks in advance !
(Sorry for any derp English)
https://linustechtips.com/topic/362738-graphics-issue/
Welcome to the forums, make sure to follow your own topics,
What are the specs of the pc?
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/362738-graphics-issue/#findComment-4916387
We already tried to reseating but we're going to try to re-install the driver, thanks.
What os is? And is there a way to see if it's just the monitor playing up?
https://linustechtips.com/topic/362738-graphics-issue/#findComment-4916452
He uses Windows 7, and yes there is, I'll tell him to try another monitor and I'll give an answer as soon as I can.
Ok cause I reckon it's the monitor causing the problem for you.
https://linustechtips.com/topic/362738-graphics-issue/#findComment-4916512
https://linustechtips.com/topic/362738-graphics-issue/#findComment-4916543
Is he overclocking anything?
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/362738-graphics-issue/#findComment-4919179
"News"
So we tried to re-install drivers but the PC froze while they were unistalling so we're not able to do that.
Fun thing, my friend said that if he runs with SAFE MODE the PC runs fine.
Any suggestions?
Have you tried a CMOS clear and reset, curious report in the picture sent, this is my only reason for suggesting this.
No, we will thanks.
https://linustechtips.com/topic/362738-graphics-issue/#findComment-4921880
"News"
Any suggestions?
No, we will thanks.
If it runs fine in safe mode it is definitely the drivers! Try everything that you can to nuke them completely and then reinstall.
https://linustechtips.com/topic/362738-graphics-issue/#findComment-4921893
THATS PROBABLY A CORRUPTION SOMEWHERE IN SYSTEM32 SO HE SHOULD RUN A DISK DEFRAGMENTER WHILE IN SAFE MODE
Stop. You're everywhere.
All caps posting is against the CoC, If i see you do it one more time i'm reporting all of your all caps posts. Got it?
OP, It's drivers. This is good news. Uninstall all drivers from safe mode, reboot and install the basic drivers (Ethernet, video, sound.). If it stays running the whole time, re install all your other drivers (chipsets, other pcie cards, etc.), and also make sure you remove any and all usb devices (save for your Keyboard and mouse).
https://linustechtips.com/topic/362738-graphics-issue/#findComment-4923903
Ok thanks you so much, I'll report when we re-install everything ;)
https://linustechtips.com/topic/362738-graphics-issue/#findComment-4924000
Hi again guys,
Bad new, we tried to re-install windows but mid process the PC restarts and starts all over.
Any ideias?
Why did you reinstall windows? It was a driver issue, you could have easily deleted the drivers while in safe mode, and re-install them.
And I'm not sure what to do about your windows installation restart problem
System: CPU - I5-6500 Motherboard - Asus B150M-A RAM - Crucial ballistix sport 2x4GB DDR4 @2400MHz GPU - RX 480 PSU - Seasonic S12II 520W Case - Aerocool Aero-800 HDD - Seagate 1TB SSD - PNY CS1311 120GB Monitor - AOC G2260VWQ6
https://linustechtips.com/topic/362738-graphics-issue/#findComment-4925173
We weren't able to re-install the driver, the PC won't allow him to uninstall the driver while in safe mode, not sure why.
https://linustechtips.com/topic/362738-graphics-issue/#findComment-4925194
What you could have done, was taking the gpu out, and using the onboard graphics to uninstall the drivers. (im not sure if you have to remove the gpu, but when my gpu is inserted I cant use my dvi connection on the mobo)
https://linustechtips.com/topic/362738-graphics-issue/#findComment-4926301
