no this one
CPU: AMD FX-9590 4.7GHz 8-Core Processor  ($296.98 @ NCIX US)
CPU Cooler: Cooler Master Nepton 280L 122.5 CFM Liquid CPU Cooler  ($139.99 @ Micro Center)
Storage: Samsung 850 EVO 500GB M.2-2280 Solid State Drive  ($197.99 @ Adorama)
Video Card: Asus GeForce GT 610 1GB Video Card  ($29.99 @ NCIX US)
Power Supply: Raidmax 630W Semi-Modular ATX Power Supply  ($25.99 @ Newegg)
Total: $1085.92
CPU AMD 9590 -- 2x Titan X ---  RAM 32GB KINGSTON---PSU EVGA 1000 ------ HARD DRIVE 2TB WD BLACK -- MOTHERBOARD AMD 900 SERIE
RAZER CRACKEN ---------RAZER NAGA -------------------RAZER CHROMA
english is new language for me so forgive my many mistake / I have moderate autism so im not always correct
no this one
Total: $1085.92
What a horrible build.
no this one
Total: $1085.92
Price limit is $500
Is this build alright for intensive web browsing?
https://pcpartpicker.com/user/Drahsid/saved/q96j4D
you could easily drop the GPU and use the onboard one without an issue saving $60!!
Gaming PC: • AMD Ryzen 7 3900x • 16gb Corsair Vengeance RGB Pro 3200mhz • Founders Edition 2080ti • 2x Crucial 1tb nvme ssd • NZXT H1• Logitech G915TKL • Logitech G Pro • Asus ROG XG32VQ • SteelSeries Arctis Pro Wireless
Laptop: MacBook Pro M1 512gb
Price limit is $500
ten u wont have a good broswer experiencx
Not bad, I would add more RAM if your browsing is really intense(Like how I use 25GB on average). 12GB should be fine though.
no this one
Total: $1085.92
8320 would be a better fit, and no motherboard? For browsing the i3 in the OP will be fine though.
I use an old dell with 8gb of ram, a core 2 duo e4500, and no graphics card as an HTPC for browsing web and streaming 1080p video. It handles it like a champ. You can get a good web browsing PC for very little money.
You know that guy that games on a MacBook? I'm that guy.
Intensive web browsing? You mean... EXTREME GOOGLE, or like lots of tabs?
So what you want is an i3, iGPU and 16GB RAM.
8gb of ram should be enough also
I'm assuming he wants hundreds of tabs open constantly. How else would it be "intensive"?
i missd motherbord
ten a macbook will go browser good
There ye go.
The A10 will also do good for basic gaming, streaming media, and is a lot cheaper than a dedicated GPU.
16gbs of RAM, cuz browsers eat that shit up. Oh yea and a better SSD, and a quiet case. ^_^
PCPartPicker part list: http://pcpartpicker.com/p/jPvqJx
Price breakdown by merchant: http://pcpartpicker.com/p/jPvqJx/by_merchant/
CPU: AMD A10-7850K 3.7GHz Quad-Core Processor  ($137.99 @ SuperBiiz)
Motherboard: Gigabyte GA-F2A88XM-D3H Micro ATX FM2+ Motherboard  ($50.89 @ OutletPC)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory  ($93.99 @ Newegg)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  ($98.95 @ SuperBiiz)
Case: Fractal Design Core 1100 MicroATX Mini Tower Case  ($37.99 @ SuperBiiz)
Power Supply: SeaSonic 300W 80+ Bronze Certified ATX Power Supply  ($36.99 @ SuperBiiz)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  ($36.99 @ Amazon)
Total: $493.79
Generated by PCPartPicker 2015-05-07 19:24 EDT-0400
... please just stop replying.. its apparent you're making things up on the spot.. a $200 computer is adequate for browsing... even a raspberry pi is capable of half decent web browsing.you certainly dont need an 8 core cpu..  even a dual core is over kill in most respects.. hell the pc in my shed is running a 4ghz pentium 4 single core cpu and 1gb ram.. its fine for browsing the web and using youtube.
OP if you're dead set on the ram front just dont use chrome as its an extreme ram hog. firefox does a slightly better job. Im a safari fan for browsing, mainly as i use my macbook for all things internet related. its the least power hungry and the nicest to components lol
There ye go.
Total: $493.79
This looks great, thanks.
ok uase a pentium then
