Does anyone know of any ITX cases that have enough room for some Water cooling stuff and a Full Modular ATX power supply
Since my Server is starting to go, I was going to Swap my server With the platform Of my Current PC and about 70% of the rest
I'm Looking an ITX Case with Room for a 170ML Tube Reservoir With My Swiftech Pump on it (I thought about mounting it outside the case if i have to.)
I Also Have a 360mm Rad that I'm not planning on using in my next build Unless I Have some Case Modding Idea For it.
However I am Planning on Fully water cooling this build.
I would like to Mount the Motherboard Horizontally instead of vertically just because I've never done a build like that mounted like that.
Right now I am only Planning on one GPU, like a water-cooled GTX 980 ITX or something like that
If anyone is wondering, The Platform for my next build was going to be a sky lake i5 cause those are suppose to be coming out later this year
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
https://linustechtips.com/topic/362342-itx-watercooled-case/
