Hi I have the AMD FX-6350 with the CM Hyper 212 Evo. I was on Speccy and i noticed my temps fluctuating from 25C-31C. Should I be worried about this? post-133822-0-94292800-1431029429_thumb.
CPU: AMD FX-6350@4.2Ghz GPU: EVGA GTX 970 SC ACX2.0 RAM: 2x4Gb Kingston Fury Black + 2x4Gb Corsair Vengeance HDD: WD Green 1Tb SSD: Kingston SSDNow V300 60Gb CASE: DeepCool Tesseract SW
 http://pcpartpicker.com/p/fJLRWZ
https://linustechtips.com/topic/362232-weird-cpu-temperature-fluctuation/
Hi I have the AMD FX-6350 with the CM Hyper 212 Evo. I was on Speccy and i noticed my temps fluctuating from 25C-31C. Should I be worried about this? attachicon.gife9a005ba3395930c24378e034e943c9c.png
No. Your CPU will fluctuate in temperature as it gets used by the system.
HydrOS (Waterworks 3.0) Pictures: // One // Two // Three
i7 5820k @ 4.3GHz (1.165v) // Asus X99-A // 16GB-DDR4 Vengeance 2400 CAS13 // RAID 0 Intel 730 240GB // Nvidia Titan X (+200Core +500Memory) // Swiftech D5 // ASUS ROG SWIFT
Are you sure the reading is correct? Try a different program.
I used HW Monitor and it is the same.
Hi I have the AMD FX-6350 with the CM Hyper 212 Evo. I was on Speccy and i noticed my temps fluctuating from 25C-31C. Should I be worried about this? e9a005ba3395930c24378e034e943c9c.png
If one would be scared about 30°c, I might as well kill myself about my cpu at 60°c ^_^
No, you are fine, all you gotta worry is if it jumps to like 60 or 70°c out of nowhere.
CPU: Pentium G3258 @ 3.2GHz || GPU:(first release,used) MSI R9 270 OC || Motherboard:MSI Z97-G45 Gaming Motherboard || RAM: 8 GB G.Skill Sniper 1600 || Monitors: Vizio 22 in Ultra slim 1080p TV || Storage: Seagate barracuda 160 GB 7200RPM,(REFURB) 1TB toshiba 7200RPM || PSU: (stripped from 2013 CAD PC)Corsair CX600 build was under $420
BE SURE TO FOLLOW YOUR THREADS! READ THIS BEFORE POSTING IN TROUBLESHOOTING!! http://linustechtips.com/main/topic/40334-read-before-asking-for-help/
