g3285 oc problem
Go to solution Solved by DeViLzzz,
http://www.overclockersclub.com/guides/intel_pentium_g3258_oc_guide/
Push it to 1.3 volts and see how far you can take your overclock.  If you continue to have more trouble look at this guide.
Well check your temperatures for one thing and share them so people can tell you if they are good or not. Also if an OC is not working properly add some more voltage and it may fix things.
temperature was 39c and voltage is 1.2 volts and same options on one guy with same Specs
https://linustechtips.com/topic/361953-g3285-oc-problem/#findComment-4906256
Too many ****ing games!  Back log 4 life! :S
https://linustechtips.com/topic/361953-g3285-oc-problem/#findComment-4906273
