I bought this to connect 2 pcs together and to the internet. I also have a printer that needs ethernet too. Did I order the wrong item? Thanks    http://www.amazon.com/TP-LINK-TL-SG108-1000Mbps-Desktop-Gigabit/dp/B00A121WN6/ref=sr_1_5?ie=UTF8&qid=1430977763&sr=8-5&keywords=ethernet+router+gigabit
 Just because you don't care, doesn't mean other others don't. Don't be a self-centered asshole. -Thank You a PSA from the people who do not say random shit on the internet.
https://linustechtips.com/topic/361897-switch-help/
Assuming you already have a modem/router to plug it into it'll be perfectly fine.
@TheGeeker Be sure to follow your own topics so you get notifications when people reply, the follow button is near the top right of the page, above the orange "reply to this topic" button.
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
https://linustechtips.com/topic/361897-switch-help/#findComment-4905475
I have a 100mbs router. I got this for the 1000Mbs. Do i need a router? My intenet is 200Mbs
https://linustechtips.com/topic/361897-switch-help/#findComment-4905477
You need to have the router.
Plug the switch into the router, the connection to your router will be limited to 100mb/s but that shouldn't be an issue.
Plug both of the computers and the printer into the switch they'll have a 100mb/s connection to the router / internet and they'll still be able to communicate with each other via gigabit assuming they have gigabit network cards and gigabit cables (won't make a difference for the printer).
https://linustechtips.com/topic/361897-switch-help/#findComment-4905487
Plug both of the computers and the printer into the switch and they'll still be able to communicate via gigabit assuming they have gigabit network cards and gigabit cables (won't make a difference for the printer).
I got  this for the fast intenet speed of 200Mbs. Any CHEAP router I can get?
https://linustechtips.com/topic/361897-switch-help/#findComment-4905492
Like 20 bucks
I don't think you'll find a router with gigabit for $20 and if you did it'd be fairly terrible, you'd be much better using the 100mb/s in the meantime and saving for a higher quality router.
https://linustechtips.com/topic/361897-switch-help/#findComment-4905498
http://www.amazon.com/NETGEAR-WNR3500L-Open-Source-WNR3500Lv2-Processor/dp/B002RYYZZS/ref=cm_syf_dtl_pl_2
https://linustechtips.com/topic/361897-switch-help/#findComment-4905504
That one should work fine.
That one should also be fine although I'd avoid buying second hand networking gear personally and I've never had good experiences with D-link but that's just me.
https://linustechtips.com/topic/361897-switch-help/#findComment-4905507
https://linustechtips.com/topic/361897-switch-help/#findComment-4905519
I got the netgear one open box on ebay for like 30 bcuks. Do I just run a cat6 from the router to the switch? How would I do that?
https://linustechtips.com/topic/361897-switch-help/#findComment-4905607
Just plug the switch into any of the "LAN" ports via a CAT5e / CAT6 cable and once you've configured the router settings according to your ISP's instructions you'll be good to go.
https://linustechtips.com/topic/361897-switch-help/#findComment-4905659
Turns out my new modem is also a router. so did not need it but i will now have it anyway
https://linustechtips.com/topic/361897-switch-help/#findComment-4912170
That's a damn good switch. Make sure you plug your (wireless) router directly into your modem provided by your ISP, then plug the switch into one of the outputs on the router.
Is it better than the router?
https://linustechtips.com/topic/361897-switch-help/#findComment-4912191
I'm going to stop you right there.  (oops, didn't see that apparently your modem is also a router)
A router and switch are not particularly interchangeable. In order to get my home network figured out I had to plug the router into the modem, then the switch into the modem.
650x487x2011-11-29_132204.jpg.pagespeed.
http://www.howtogeek.com/99001/htg-explains-routers-and-switches/
https://linustechtips.com/topic/361897-switch-help/#findComment-4912217
Yes. I have this
Not the best sorry
                          100Mbs Switch (Goes thought House)
Modem/router-----|
                            Netgear gigabit router---- Tp Link switch --- Pc and stuff
Is thus better that just the router?
https://linustechtips.com/topic/361897-switch-help/#findComment-4912231
Yes. I have this
Not the best sorry
Modem/router-----|
There should be no performance difference. The switch acts as a way to get more ethernet ports from a network device. The setup you have right now should actually work if your modem is really a router as well.
https://linustechtips.com/topic/361897-switch-help/#findComment-4912243
Is there any gain for using the switch of the router and not the modem/router?
https://linustechtips.com/topic/361897-switch-help/#findComment-4912264
