Can I control my fans when I connect them to a fan hub, and then connect the fan hub to the mobo ??? Let's say I have some 3-pin fans connect to a fan hub and the fan hub (3-pin) connect to the mobo. Does it work the some way as connect a single fan to a fan header on the mobo???
https://linustechtips.com/topic/361862-fan-hub/
If the entire fan hub is powered off the header, then yes it will be controlled the same way as a single fan. However if you're only running off the the header alone, it's not recommended to run too many fans as to risk burning out the header. The combined power draw for all fans connected to one header should add up to less then 1A.
So for two fans, maximum 12V @ 0.5A each
Three fans, maximum 12V @ 0.33A each
Four fans, maximum 12V @ 0.25A each
Five fans, maximum 12V @ 0.2A each
I would definitely not run more then 5 off one header, even if power draw doesn't exceed 1A.
"Rawr XD"
https://linustechtips.com/topic/361862-fan-hub/#findComment-4905053
Just get a NZXT Grid +. Individually control each fan and set them to ramp up according to CPU temp or GPU temp and the software literally has like zero bugs. AMAZING
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/361862-fan-hub/#findComment-4905146
I have at least 10 fans so I can't lol
How can I know how many ampe each fan's gonna run at ?
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181071&cm_re=corsair_SP120-_-35-181-071-_-Product
This is my fan or at least my fan will be from corsair only.
https://linustechtips.com/topic/361862-fan-hub/#findComment-4914283
http://www.corsair.com/en-ca/air-series-sp120-led-red-high-static-pressure-120mm-fan-twin-pack
0.26A each
But why use only Corsair? They don't make that good of fans.
"Rawr XD"
https://linustechtips.com/topic/361862-fan-hub/#findComment-4915550
0.26A each
Can you suggest to me some brand that has only black/white fans with led ? And please don't be like $25 for 1 fan lol
https://linustechtips.com/topic/361862-fan-hub/#findComment-4920118
There's not that many good LED fans, if for some reason you need LED then the Bitfenix Spectre (non-pro) are decent. That and the Corsair are about all you're going to get.
If you actually want good fans for the money, you're not going to get LEDs unfortunately.
"Rawr XD"
https://linustechtips.com/topic/361862-fan-hub/#findComment-4920174
well basically because my case is the 780T and I want the front fans to have led. If there's a way for me to put some led there that's going to look good then I would find some other brand with better fans. I need high static pressure and quite fans.
https://linustechtips.com/topic/361862-fan-hub/#findComment-4920429
cougar make good led fans, 15 usd ish
https://linustechtips.com/topic/361862-fan-hub/#findComment-4920435
