I want to build new x99 budget build. I don't want to waste lot of money but I also want to get x99 performance.
My current parts that I have chosen are:
CPU: 5820k
CPU cooler : nzxt x61 (I want RGB lights)
GPU: gtx 980 nc acx 2.0
Motherboard : Msi X99A Sli plus
memory: WD black 3tb
               samsung 850 evo 250gb
psu: cooler master v850 (I know it's little overkill but I'm planning to add another gtx980 later)
ram: corsair vengeance LPX 2666Mhz DDR4 16gb
case: corsair 760t (just in case. I know it cost lot but looks are very important for me)
keyboard and mouse : k70 rgb ; logitech g502
All help is appreciated please suggest anything you'd like.
I basically need suggestions of what to replace in the system.
https://linustechtips.com/topic/360120-need-help-building-new-pc/
So, what exactly are you asking?
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
Use pcpartpicker so it's easy to edit and change for everyone then you will get more advice quickly.
The words "X99" and  "budget" dont go together. What are you planning to use it for?
Quote me if you want me to see your message. Like my post if it helped. Click "Show More" to see things that I use.
Desktop (2014): CPU: Intel Core i5 4690k @ 3.50GHz | GPU: MSi GTX 970 Gaming 4G | Motherboard: MSi Z97 Gaming 5 | RAM: 2x4GB G.Skill RipJaws X 1600MHz + 2x4GB HyperX Black 1600MHz | SSD: Samsung 750 Evo 120GB | HDD: WD Black 1TB | Cooler: Cooler Master Hyper 212x | PSU: Corsair VS650 | Case: Cooler Master Elite 431 Plus | OS: Windows 10 Home
Laptop (2017): Model: Asus UX310U
Peripherals: Monitor: Samsung S24D300 OC@75Hz + Viewsonic XG2401 (144Hz) | Mouse: Logitech G305 | Keyboard: Razer Blackwidow Chroma V2 | Headset: HyperX Cloud Core | Speakers: Logitech Z333 | Additional: Logitech G29
Mobiles: Samsung Pixon (2010-2012) | Samsung Galaxy Ace (2012-2013) | Samsung Galaxy S3 (2013-2016) | Samsung Note 4 (2015)(Lost) | Samsung Galaxy S7 (2016-2019) | Samsung Galaxy S10 (2019 - Current) | Additional: ASUS Zenwatch 2 (2016)
