So i am looking at phone providers( a big deal when you suddenly have to pay for your phone contract on your own) and i found that fido would be the most economical for me.
I need connection is the circled locations, so how would it be
How would the theoretical connection and speeds be
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
https://linustechtips.com/topic/359854-gsm-connection/
-I really love to snip-
Why do you have to pay for it on your own?
00110000 00110001 00110000 00110000 00110000 00110000 00110001 00110000 00100000 00110000 00110001 00110001 00110000 00110001 00110001 00110001 00110001 00100000 00110000 00110001 00110001 00110001 00110000 00110000 00110001 00110000 00100000 00110000 00110001 00110001 00110000 00110000 00110001 00110000 00110000 00100000 00110000 00110001 00110001 00110000 00110000 00110001 00110000 00110001 00100000 00110000 00110001 00110001 00110000 00110001 00110001 00110000 00110001
https://linustechtips.com/topic/359854-gsm-connection/#findComment-4879747
Well, I'd imagine it would be exactly how the map says it would be...
What exactly are you asking?
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/359854-gsm-connection/#findComment-4879748
GSM = 2G
EDGE =  beefed up 2G, I would call it 2.5G.
HSPA = 3G
4G HSPA+ = beefed up 3G, marketed as 4G. I would call it 3,5G
LTE  = real 4G
The beefed up ones are just slightly faster than what it's based on. So don't expect much difference between them.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/359854-gsm-connection/#findComment-4879751
how connection speeds and usage would be
My Rig
Total: $2074.22
https://linustechtips.com/topic/359854-gsm-connection/#findComment-4879756
parrents pay for a talk and text only plan, i have a need for data and have to pay for it myself
My Rig
Total: $2074.22
https://linustechtips.com/topic/359854-gsm-connection/#findComment-4879761
Well
Well 2G and 2.5G are slow as hell. Here in Belgium so slow it's useless.
3G and 3.5G. Fast enough for almost everything. If you are a bit lucky, you can view youtube videos, stream internet radio, just browse a bit. All fine
4G. Well that's just like the fibreglass of the mobile networks. Fast enough for pretty much everything you coud possibly want.
https://linustechtips.com/topic/359854-gsm-connection/#findComment-4879785
Well the speeds of the network aren't going to matter as far as the map goes. And as far as coverage goes, well the maps I have seen are fairly accurate.
The speed of the network is going to matter on how much bandwidth your ISP allots you in their pool of bandwidth. LTE current spec stipulates 150mb download by 50 upload, which no one actually gets. That just means your phone and the tower can talk that quickly. Your ISP still probably only has a gigabit (maybe a 10GBps connection if you're lucky) going to each of their towers, so you will have to split that data with all the other customers associated with that tower.
https://linustechtips.com/topic/359854-gsm-connection/#findComment-4879788
