Hi.
So a about half a year ago i build a a fairly huge computer, with a corsair obsidian 750D case. Now i'm moving into a smaller apartment, so i want to make the PC a bit smaller and more quiet. The last bit i have figured out, but the case options out there is a jungle. I have an E-ATX motherboard so i cant really just go buy the smallest case available, and i don't want to change anything either.
So my question to you guys is:
Whats the smallest case available that can fit an E-ATX motherboard?
It would really help me a lot. Feel free to ask anything you wanna now about the build, or what you think i didn't include here.
Sorry if i didn't make myself super clear, English isn't my first language.
 Thank you very much
https://linustechtips.com/topic/359732-smallest-e-atx/
There is a Rosewill Mid Tower that fits E-ATX Motherboards, and you could also mod a case to fit it.
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
https://linustechtips.com/topic/359732-smallest-e-atx/#findComment-4878430
Wow. yeah i see that. but damn it's ugly though, no offense.
I don't really feel comfortable modding a case though. Don't really have the tools or the skills.
But Thank you very much.
If someone else wanna look here's i link i found: http://www.newegg.com/Product/Product.aspx?Item=N82E16811147175
https://linustechtips.com/topic/359732-smallest-e-atx/#findComment-4878449
The smallest EATX case out there is the Magic Cube AIO by Cubitek.http://www.cubitek.com/products/magic-cube
It's fairly well ventilated, and very small. Check it out in detail, it's a great case.
This is a place where you can buy it: http://www.quietpcusa.com/Cubitek-Magic-Cube-AIO-EATX-Computer-Case-P920.aspx
https://linustechtips.com/topic/359732-smallest-e-atx/#findComment-4878514
  • 1 month later...
