Audio Through HDMI
Solved by SlayerOfHellWyrm,
Got it. Turns out the new Realtek driver was interfering with my Nvidia driver, is my guess. Running the driver installer, causes it to remove the old driver, restart, install the new driver, and restart again. The reason it disappeared on me, was because I never did the 2nd restart last night once I saw I had both speakers up. This was really some other driver taking over,which given the video is coming from my 765M, I'm assuming it took over the audio portion.
Regardless of what driver it's currently using for my audio, letting the Realtek installer remove the old driver, and then cancelling the new install has fixed the problem. The reg key edit I had before, must've enabled the driver it's currently using.
