Budget: $1000 USD, peripherals not included
CPU: 3570K
Motherboard: Gigabyte GA-Z77MX
GPU: EVGA GeForce GTX 760
RAM: CORSAIR Vengeance 8GB (2x4GB)
HDD: WD Green 1.5 TB
SSD: Samsung 840 120GB
Optical Drive: ASUS DVD Burner
Case: NZXT Source 210
Power Supply: NZXT Ready Crossfire 750w
Thoughts?
CPU: i7-4770k CPU Cooler: NH-D14 RAM: Crucial Ballistix Sport 8gb GPU: EVGA Superclocked 780 ti MOBO: ASUS Maximus VI Gene PSU: Corsair RM 850 Case: Bitfenix Prodigy M
https://linustechtips.com/topic/35882-first-build/
Its fine to download its just a newegg post.
Use PCPartpicker.com next time though. Is our budget 1000 dollars? There is much better you can do.
What would I change to make it better?
https://linustechtips.com/topic/35882-first-build/#findComment-459792
https://linustechtips.com/topic/35882-first-build/#findComment-459920
Well if that's your budget I can build you something. Is it for gaming? Video editing?
Gaming, I want to build, just tell me parts
https://linustechtips.com/topic/35882-first-build/#findComment-459948
It's a good build. Leaves plenty of room for upgrades.
I wouldn't change anything besides the Gigabyte board simply because of the colors. I don't like Gigabyte boards. Too many different shades of blue. But that's just me.
It'll be great for gaming.
I would do what WoodenMarker suggested and read that before posting and follow the guidelines in it. Just saying.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/35882-first-build/#findComment-459969
Thanks, I was lead to you by Worth.
https://linustechtips.com/topic/35882-first-build/#findComment-459999
I suggest a ~600w PSU, the Corsair TX 650 v2? Also I would also get a 7950 instead.
I'm using the 750w for updates later, @Vitalius, thoughts on 7950?
https://linustechtips.com/topic/35882-first-build/#findComment-460042
The 7950 outperforms the 760 and overclocks better. Get the 760 only if you want shadow play or need the cuda cores.
For a 7950 crossfire, a decent 750w would do and as for a 760 sli, a good 650w would suffice.
If by updates, you don't mean adding another card but more fans and drives, a single 500-600w will be plenty.
https://linustechtips.com/topic/35882-first-build/#findComment-460065
I see you sacrificed storage for a better gpu. I'm pretty sure the OP got a larger hdd for a reason.
As for the gpu, a 7970 is a cheaper option that has performance that is neck to neck with the 770.
https://linustechtips.com/topic/35882-first-build/#findComment-460077
I would stick with the 750w for updates later as you said and I prefer NZXT PSU's and cases myself.
As for the 7950, since you are planning updates later, I would stick with the GTX 760. Yes, AMD is planning to fix the frame stuttering in Crossfire with an update soon (not sure when, may have already happened), but I wouldn't trust that. When it comes to drivers for SLI/Crossfire, I don't think either side can be trusted very much to upgrade their current performance. And for SLI VS Crossfire, Nvidia's is currently better imo.
That's why I would just stick with the 760 even if a 7950 does have better price-performance ratio. You plan to upgrade, and AMD's frame latency (even on single GPU's) isn't great. It's not even good.
https://linustechtips.com/topic/35882-first-build/#findComment-460086
Not much, I did pick a larger SSD, and at the very least, he can switch out the SSD I chose, for the one he originally picked, still be under his old budget AND be able to get a 2TB storage drive. So yeah.. no.
https://linustechtips.com/topic/35882-first-build/#findComment-460114
