Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/358737-thoughts-on-build/#findComment-4867540
also that cooler is fine
Solitaire.
https://linustechtips.com/topic/358737-thoughts-on-build/#findComment-4867542
definitely a solid build, although you may end up finding 1tb woefully inadequate.... at least i do
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/358737-thoughts-on-build/#findComment-4867545
Seems pretty good, the only thing I would change is the PSU to 750W, just to be safe. Otherwise, it's a pretty good build.
Are you kidding me, 650W is more than enough.
That would be enough for SLI
If anything I would go down to 500W or 550W
https://linustechtips.com/topic/358737-thoughts-on-build/#findComment-4867548
