Hello.
I noticed a few weeks ago that the logo LED of my H440 has become very weak.
I'm really sorry that I can't post the pictures here as LTT.com gets weird with pic sizes. Just take a look at this imgur album if you feel like it.
Has this happened to some of you?
Cheers
https://linustechtips.com/topic/358582-weak-h440-logo-led/
Just to quickly check there would be no reason that your psu wouldn't be providing enough power to it?
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/358582-weak-h440-logo-led/#findComment-4865431
Copy this into your post:
Case LEDs off, logo LEDs off
Case LEDs off, logo LEDs on
Case LEDs on, logo LEDs on
case LEDs on, logo LEDs on
Day one
[spoiler][img]http://i.imgur.com/p41aiOV.jpg[/img]Case LEDs off, logo LEDs off[img]http://i.imgur.com/mFGxPFS.jpg[/img]Case LEDs off, logo LEDs on[img]http://i.imgur.com/SoJZkfO.jpg[/img]Case LEDs on, logo LEDs on[img]http://i.imgur.com/vfRkQJ6.jpg[/img]case LEDs on, logo LEDs on[img]http://i.imgur.com/4QD8ifK.jpg[/img]Day one[/spoiler]
Sig under construction.
https://linustechtips.com/topic/358582-weak-h440-logo-led/#findComment-4865453
It reports that i cannot use "this Image extension"
https://linustechtips.com/topic/358582-weak-h440-logo-led/#findComment-4865505
That's pretty much impossible, as I have a Corsair RM550 80+ Gold PSU
Ok well that's my only idea so...
https://linustechtips.com/topic/358582-weak-h440-logo-led/#findComment-4866035
Make sure the power to it is plugged in all the way. Mine came unplugged a bit and just pushing it in more helped.
CPU: Ryzen 5 5600 Motherboard: MSI B550 Tomahawk RAM: 32Gb DDR4  GPU(s): MSI 6800-XT Case: NZXT H440 Storage: 4x 250gb SSD + 2TB HDD PSU: Corsair RM850x with CableMod Displays: 1 x Asus ROG Swift And 3 x 24" 1080p Cooling: H100i Keyboard: Corsair K70 RGB Mouse: Corsair M65 RGB Sound: AKG 553 Operating System: Windows 10
Current PC:
http://i.imgur.com/ubYSO3f.jpg          http://i.imgur.com/xhpDcqd.jpg
https://linustechtips.com/topic/358582-weak-h440-logo-led/#findComment-4866055
