DRIVERS problem how do i get them?
Go to solution Solved by kristaps552,
go into device manager, and check for hardware ID's, and then just look up the VEN code online, and it will give you the right driver.
ok i will be short
there is two PCs one with wifi(main) one with out(server) the server has missing internet drivers. why do i need them? it will be a server between my main pc and the server pc with wired connection on a wifi router that has no internet connectivity.
how do i install network drivers how do i find out witch ones do i need? is there a pack of drivers for windows XP SP3
and will hamachi work with out internet?
https://linustechtips.com/topic/358404-drivers-problem-how-do-i-get-them/
ok i will be short
visit the motherboard manufacturers website and download them from there
Case:NZXT H440   CPU:3570k @ 4.4ghz   Cooler:Prolimatech Megahalems w/ ap121 p/p  GPU:Gigabyte Windforce GTX 770  RAM:Crucial Ballistix Tactical Tracer 16gb 1600mhz  Mobo:Sabertooth Z77     PSU:Cooler Master Silent Pro M 700w   Wheel: Logitech G27 + joystick as handbrake Asus DGX 5.1        Mouse: Corsair M65     Keyboard: CM Storm Trigger Cherry MX black  Headphones: ATH-M50s    Phone: Nexus 5 32GB  Earphones: Sennheiser CX 400ii    SSD: 120gb 840 evo  HDD: WD Enterprise 2TB    AMP&DAC: Schiit Stack.
