I am after a enclosed portable USB msata 240-256gb SSD
I just want to make the best decision
Im considering the samsung t1 250gb
Im also looking at the crucial mx200 msata + an enclosure
1. Do enclosures like slow down the SSD in comparison to the premade samsung t1?
2. Which enclosure is best?
3. Id perfer the 16nm MLC over the TLC V NAND
4. Will most msata 3 max out USB anyway so I only need an average one?
I don't want to spend over 200 AUD (160 US) shipping included, id rather pay less.
What do you guys think?
https://linustechtips.com/topic/357763-need-help-picking-a-portable-ssd-solution/
Have you checked Corsair's 128GB/256GB SSD Thumbdrives? I've only heard good things about them - and the 'Survivor' has a pretty beefy enclosure.
http://www.corsair.com/en/flash-survivor-stealth-usb-3-0-256gb-usb-flash-drive
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
it may be cheaper to use the HDD enclosure + SSD
the Samsung T1 still rely on USB 3.0 speeds
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
I am after much faster than this, even corsairs GTX doesn't get close to the T1 and I would like a small USB cable just in case it breaks.
Then I feel buying a HDD enclosure and putting a normal SSD in would be your best bet.
I am after something that can fit it to my pocket so msata would be ideal.
