Ok so I was having trouble with installing an OS on a laptop, so I took the drive out and threw it into my desktop to install the OS. once completed and was able to boot to the desktop, I shut down my computer, took the drive out and threw it back into the laptop. Once put all back together I booted and it instantly went into the bios screen. I go to check boot order and there is nothing there for HDD, not even the thumb drive I had in would show. Does anyone have and ideas on what the problem could be.. The laptop is an ASUS Q301L
https://linustechtips.com/topic/357688-laptop-help-asap/
when you build the OS in your desktop
the OS takes your registry and driver of your desktop
not your laptop specs
that is why you get the BSOD
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/357688-laptop-help-asap/#findComment-4853533
