I'm building my first computer and was wondering if I am doing everything right.
Here is my build:
intel core i5 4670k
Gigabyte gtx 760 2GB
COOLER MASTER seidon 240mm cpu cooler
Corsair Vengeance Pro 8GB(2 x 4GB)
MSI z87- G45 Mobo
Segate Barracuda 2TB 7200rpm
Asus  DVD Burner- OEM
SeaSonic G Series 550w psu
Windows 8 64 bit OEM
Corsair Carbide Series 300r(windowed)
I'm not looking to go spend an extreme amount of money here.
Also I'm buying this on newegg.com if that helps.
A little update:
I was wondering if it it is better to get a larger SSD for a boot drive/drivers/games or get a smaller SSD for boot/drivers and get 16GB of ram and dedicate 6GB to AMD RamDisk
hmm
https://linustechtips.com/topic/35763-first-build-help/
WINDOWS 8, NEVER! go with windows 7, please, more game support and NO RIDICULOUS UI
Available from 3pm to Midnight Eastern Time (GMT-5). (>'-')> <('-'<) ^(' - ')^ <('-'<) (>'-')> You can't stop the kirby dance.
4770k | Gigabyte GTX 970 Mini | Lian Li PC-TU100B | MSI Z87I 2x8GB G.Skill Sniper | Noctua NH-L9i Silverstone Strider 450W SFX | Windows 10 | 2x 250GB 840 Evo Rad 0 1x 1TB WD 2.5" | 25% gaming, 25% CAD and rendering, and 50% web browsing.
https://linustechtips.com/topic/35763-first-build-help/#findComment-458241
That looks like a good overall build. Just 1 thing I would think of getting a smaller Hard Drive and getting an SSD. Other than that your good:)
O and its no problem but in future could you post things like this here:http://linustechtips.com/main/forum/18-new-builds-and-planning/
Life is pain. Anyone who says any different is either selling something or the government.
----CPU: FX-6300 @ 4.2ghz----COOLER: Hyper 212 EVO----MOBO: MSI 970A-G46----PSU: OCZ 600watt----CASE: Black Corsair C70----GPU: Sapphire 7870 dual fan ghz edtion----2 random HDD'S----A couple fans here and there. Mouse: Gigabyte M6900-------Keyboard: Logitech G105-----Mousepad: Steel series something something.
https://linustechtips.com/topic/35763-first-build-help/#findComment-458243
Good build, I would change the 2TB to 500GB and 128GB/256GB SSD and I would go for Windows 7, Windows 8 is more for tablet or other touchscreens IMO ;)
CPU: Intel Core i7 4790K @ 4.4GHz (cooled by Corsair H110) Motherboard: ASUS Maximus VI Formula RAM: 16GB DDR3 1600MHz CL9 | GPU: ASUS GTX780TI-DC2OC-3GD5 Case: NZXT Phantom 630 Storage: Samsung 840 Pro 128GB + 3 x WD Black 500GB  + WD Black 1TB + WD Black 2TB + Kingston V300 120GB PSU: SeaSonic Platinum 660W Monitors: 3 x Iiyama ProLite XU2390HS-1 Keyboard: Logitech G910 Orion Spark Mouse: Logitech G502 Protheus Spectrum Mousemat: Steelseries QcK Heavy (40x45) Headset: Kingston HyperX Cloud II Speakers: Logitech Z906
https://linustechtips.com/topic/35763-first-build-help/#findComment-458270
2TB is a little high but 500GB is also a little small, 1TB should do fine,
There are 10 types of people in the world: Those who understand binary, and those who don't.
Just some helpful stuff: You're - You are, Your - Your car, They're - They are, Their - Their car, There - Over there.
Folding @ Home Install Guide and Links | My Build
https://linustechtips.com/topic/35763-first-build-help/#findComment-458332
It depends on how much he needs ;)
https://linustechtips.com/topic/35763-first-build-help/#findComment-458393
True, I was just giving an example from personal experience.
https://linustechtips.com/topic/35763-first-build-help/#findComment-458408
