So I finally bit the bullet and bought Sony Vegas, Just for home movie editing etc...
But when I try and render with CUDA it reverts back to using the CPU.
Anyone by chance know a fix ? Using a 780 Ti.
Battle.Net - Dicehunter#2746
Origin - Dicehunter
Steam - Dicehunter
Uplay - Dicehunter
https://linustechtips.com/topic/357490-sony-vegas-cuda/
i had the same problem and sorry to say but sony vegas suck's at using all cuda cores
essentially vegas can only use a quarter of the cuda cores on new kepler and maxwell gpu's and your basically fucked and can't do anything
EDIT: my advice try your best so get a refund and move to adobe premiere that with a simple text edit you can get cuda working, this is why i moved to premiere
Edited by nikolaizombie1
https://linustechtips.com/topic/357490-sony-vegas-cuda/#findComment-4851092
Thanks for the advice bud, Got a refund and tried Adobes solution, Works great and will buy it when my refund goes through :)
Origin - Dicehunter
Steam - Dicehunter
Uplay - Dicehunter
https://linustechtips.com/topic/357490-sony-vegas-cuda/#findComment-4858236
