Hello, I have a non-modular power supply and a hard drive that I need to connect to power. Trouble is, all the Molex connectors on my power supply unit are being used. I know that I need an adapter/splitter but I don't know what it is called. It is a female molex connector coming from my HDD. Please help me out, I really don't want to screw this up. Pretty new to this.
post-185115-0-51918400-1430334352_thumb.
  • AMD Athlon X4 760K CPU   |   MSI FM2+ ATX A88X-G45 Motherboard   |   8GB 1600MHz RAM   |   MSI GTX 760 GPU (Reference)
  • Thermaltake Versa H22 Case   |   1TB Seagate, 0.5TB Hitachi (7200RPM)   |   ArcticRed+ 700WStock    |   Windows 8.1
https://linustechtips.com/topic/357448-power-to-hard-drive/
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
https://linustechtips.com/topic/357448-power-to-hard-drive/#findComment-4850484
https://linustechtips.com/topic/357448-power-to-hard-drive/#findComment-4850517
Basically. On my power supply there are 4 male molex connectors coming out of it. All of them are being used but I need a fifth connector to power a 1TB HDD that I have. The female molex in the image is the type of connector it is.
I think what I need is a 1 female to 2 male Molex splitter, can anyone confirm that?
https://linustechtips.com/topic/357448-power-to-hard-drive/#findComment-4850540
Don't like the psu but there is the stuffhttp://www.amazon.co.uk/gp/aw/d/B000067SLY/ref=mp_s_a_1_2?qid=1430336689&sr=8-2π=AC_SY200_QL40&keywords=molex+splitter&dpPl=1&dpID=41XV0vGiStL&ref=plSrch
And
http://www.amazon.co.uk/gp/aw/d/B0048OHTGM/ref=mp_s_a_1_1?qid=1430336857&sr=8-1π=AC_SX200_QL40&keywords=molex+to+sata&dpPl=1&dpID=31i5RkR90HL&ref=plSrch
https://linustechtips.com/topic/357448-power-to-hard-drive/#findComment-4850776
Hey Joegeddon,
I would try contacting the manufacturer of the PSU to double-check if it is safe to use more connectors than provided. Also they could guide you to some supported solutions. :) Otherwise, you can always use your storage drives externally via a SATA to USB cable, docking station or a simple external enclosure.
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/357448-power-to-hard-drive/#findComment-4854561
I just realised I got the connectors mixed up. The male Molex looks like a female Molex because it has the plastic cover around the pins. I was just being stupid, I know what I need now.
I will contact ArcticRed and look into it. Thanks for the advice anyway.
https://linustechtips.com/topic/357448-power-to-hard-drive/#findComment-4860042
