Recently i downloaded Ventrilo (64 bit version) and ventrilosrv (there's just 32 bit).After installing without any problem both of them i cant run ventrilosrv.exe because i get "you can not access...Could be you dont have permision" ... This can be windows 8.1 problem? my os account is set as admin but still i cant get it working...
https://linustechtips.com/topic/357356-urgent-problems-with-ventrilo/
Is the server running in the background?
(Check processes/services/taskbar etc).
No..The problem is i cant even run the server,since i need to edit the ini file for creating my own..i cant access to any file in ventrilosrv folder :/
oh and you can't always edit ini files with notepad while they are in program files, copy it to your desktop, make your changes then replace the one in program files and you'll get the prompt for admin permission.
Notepad can't cope with elevating permissions on an edit for some reason
Okay. I've had installations install a service during the install process that starts when windows starts, and you have no idea it is. That's more of what I was concerned about.
Give what @Beltboy says.
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
