Well, I've tried.. Really tried...
I've searched high and low for a laptop with these requirements..
An Intel Core i processor..
Dedicated graphics card... (An Nvidia 840m or higher)
Ram not important.
Storage not important.
IPS screen and touch
Budget, I really don't wanna go over 1k on this...
But the only thing I've found that fits all the above is the HP Omen. Dx That's 1400$ It's sooo expensive....
Could anyone please shed some light into this failure of search situation? ;;;;;
https://linustechtips.com/topic/357295-need-help-finding-a-laptop/
Ram not important.
Alienware 13 is $999 with a 960m (but no touch)
What you want doesn't exist at that price, that is why you cannot find it
The leveno Y50 sounds like your best choice
This guy has a good point, the Lenovo Y50 is a good choice except...
It's got a hinge issue where it breaks off on it's own.. I'm scared of it......... No other laptops? Even if they cross the 1000$ range but not more expensive than the 1499 Omen?
Damn it I don't know how to delete posts.... I wanted to multi quote this, sorry, new.. xnx
Acer VN7-591G-73Y5 no touch.
I feel like you will get a lot more for spending 200 dollars more and that it might even be worth it. Also the 840m isn't really a that great ...
http://www.videocardbenchmark.net/high_end_gpus.html
I think the new intel iris is better ...
snip
Take a look at the HP ENVY 15. You can customize it to have a touch screen and an 850m.
CPU: AMD FX-6300 4GHz @ 1.3 volts | CPU Cooler: Cooler Master Hyper 212 EVO | RAM: 8GB DDR3
Motherboard: Gigabyte 970A-DS3P | GPU: EVGA GTX 960 SSC | SSD: 250GB Samsung 850 EVO
HDD: 1TB WD Caviar Green | Case: Fractal Design Core 2500 | OS: Windows 10 Home
