So I have recently been interested in creating a water-cooling loop for my system, before I begin here are my specs.
Hardware
CPU: i7 4790k @ Stock (Stock Cooler)
Motherboard: GIGABYTE Z97X SLI UD3H
GPU: 2 x XFX R9 280X 3GB
RAM: GSKILL 8GB RipJaws Gaming Ram
Case: NZXT H440 White
I have been running the 4790k at stock for a while and obviously not just for aesthetics but as well as performance why not increase it if the option is available.
I would only like a loop that cools my CPU, if there is any reservoir and pump combos that are under the price of around $100 that are great quality and YOU would personally recommend i'd prefer that really.
If you guys can recommend any parts that are listed below for cheap prices, please do :)
Cooling
Radiator (240mm):
Reservoir & Pump Combo:
Acrylic Tubing:
CPU Block:
Good Fans (preferably white):
Liquid Coolant (white):
https://linustechtips.com/topic/357225-small-watercooling-loop/
Not sure if you would be able to do it for $100 but I would recommend looking at some of EK's stuff. They sell pretty much everything you would need for making a water cooling loop.
I would also recommend PETG tubing instead of acrylic since it doesn't crack.
CPU: 6600K @ 4.6Ghz | COOLER: H100i GTX | MOBO: Asus Z170 AR | GPU: EVGA GTX 1080 Ti Hybrid | RAM: G.Skill Trident Z RGB 16GB |
CASE: Corsair 760T | PSU: Corsair RM750x | STORAGE: Samsung 850 EVO 250GB & Seagate 2TB | KEYBOARD: K70 RGB | MOUSE: Deathadder Elite
https://linustechtips.com/topic/357225-small-watercooling-loop/#findComment-4847785
Recommend any?
The problem is an expandable pump is quite expensive ;
you could get a cheaper pump but then you would loose the ability to cool my gpu later down the line .
Recommend what is best, not what you preffer.
"Like" comments to show your support of them or the idea they express.
https://linustechtips.com/topic/357225-small-watercooling-loop/#findComment-4847792
