How does my build look?
Solved by Flight1sim,
I'm not planning to really overclock so I guess the liquid cooling is overkill, so I was thinking of replacing with a fan cooler to lower the price and the Noctua was recommended. So two 140mm in the front and 1 in the back? Only get two stock in the r5 fractal. Btw thanks for your help a lot man!
Hey no problem, i'm glad to help someone so polite! ![]()
so the r5 has one 140 on the front and 1 120 in the back? In that case, you should consider going with a noctua fan for the heatsink, only 1 is really required; but It's okay to go with Push-Pull as well, i'm not really too familiar with noctua fans tho unfortunately ![]()
But if you go with a corsair fan, i'd say go with an SP fan for the heatsink
