yup
 Asus M5A99X Evo  - AMD FX-8350 - 16GB Corsair Vengeance 1866Mhz - Corsair 120mm Quiet Edition Fans BenQ XL2411Z- EVGA GTX 980 Superclocked Fractal Design Define R4 - Corsair H100i - 2 TB 7200rpm HDD - Samsung 840 Evo 120GB - Corsair RM750w PSU - Logitech G502 Proteus Core - Corsair K70 RGB MX Red - Audio Technica M50x + Modmic 4.0 - LG 23EA63V x2
Spinthat Spinthat Spinthat Spinthat
https://linustechtips.com/topic/356941-will-it-get-bottleneck/#findComment-4844290
Yup!, but so will the i3 at the same price.
Best choice would be to get a 970/i5 combo.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/356941-will-it-get-bottleneck/#findComment-4844311
I see some bottlenecking with my GTX 970 and FX-6300. The answer is yes, the 980, a brand new $500 graphics card, will be bottlenecked by a $100 3 year old CPU
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/356941-will-it-get-bottleneck/#findComment-4844322
Will an AMD FX 6300 bottleneck a GTX 980? Any answer would be appreciated!
Most definitely.
I'd only go as high as a GTX-960 or R9-280x if I had a FX-6300.
Go i5-4590, i5-4690k, or i7-4790k if you want or have: GTX-970, 290x, 980, 295x2, or Titan X.
CPU: Intel i5-4690k                                                               RAM: 16gb Corsair Vengance Pro DDR3-2400        Case: NZXT S340
Cooler: CM Hyper 212 Evo                                                  Storage: Intel 730 SSD        PSU: EVGA 850G2
Mobo: Asus Z97-A 3.1                                                          GPU: 980ti G1        OS: Windows 10 Pro
https://linustechtips.com/topic/356941-will-it-get-bottleneck/#findComment-4844336
Yes.
https://linustechtips.com/topic/356941-will-it-get-bottleneck/#findComment-4859478
