I have the G1 GTX 970 and For some reason, Whenever I push it past +270, I get errors in OCCT, Although I don't get any Artifacting. Why is this, Is +270 just my Max OC or is OCCT bad when it comes to memory
Thanks
 Case: Define R5 I GPU: G1 GTX 970 I CPU: i5 4690k I RAM: G.Skill Ripjaws X I PSU:  EVGA 750B2 I Cooler: Noctua NH D15
MB: ASUS Z97-A I SSD: Crucial MX100 256GB I HDD: WD Black 1TB
https://linustechtips.com/topic/356296-issues-with-memory-oc/
Artifacting is more of a late warning. Memory can spit out a lot of errors before artifacting makes itself known. I've noticed this a lot with Maxwell where overclocking memory can run stably with insane clocks but it's not benefiting performance because it's spitting out errors.
4K // R5 3600 // RTX2080Ti
https://linustechtips.com/topic/356296-issues-with-memory-oc/#findComment-4836386
So Would +270 Be my max OC For the memory or should I not push it any higher considering that I get Errors In OCCT
https://linustechtips.com/topic/356296-issues-with-memory-oc/#findComment-4836392
