May I first say that this cooler is amazing. Not only in looks but performance. Definitely warrants me buying it. My question is, it's a bit of a different way of cooling. Compared to the say Corsair AIO liquid coolers, the fans are mounted differently to pull in air from the outside as opposed to the inside. With my setup of two intakes on the front, one on the bottom and an outtake on the back, there will be so much more outtakes as opposed to intakes. If you own this cooler, how do you have it setup? If you dont, what do you think is ideal? It's a bit of a finicky thing.
I'm going to punch your face- IN THE FACE.
https://linustechtips.com/topic/355758-swiftech-h220x-fan-setup/
