So I am looking at investing in a low power PC that's small, I wouldn't mind a nuc but I know I can get a slightly larger PC (cm case) at cheaper prices.
So the usage is this.
It would be on Linux, so Intel is preferred due to drivers although apu maybe an option due to next usage.
Light gaming, indie stuff more than likely most demanding game would be tf2 on this thing.
Other usages are video at 1080p, programming etc.
I may have it also as a small nas, just for small work backups I trust Linux with btrfs more than I trust ntfs.
What processor would you suggest and if entirely possible avoiding dGPU unless its low powered (PCI bus power only -75w or under) and cheap
Thanks
What does an Transformer get? Life insurance or car insurance? - Russell Howard - Standup (Made me giggle a bit)
https://linustechtips.com/topic/355652-low-power-pc-suggestions/
Thanks
AMD 5350 apu is a quad core 25w and would be great for a low power build and can play like 2d indy games. Kaveri a8-7600 also has a configurable tdp of 45w, and can well hande even Battlefield 4 on low-med.
 junker build in the making
https://linustechtips.com/topic/355652-low-power-pc-suggestions/#findComment-4828425
Yup, however I know first hand that it's not powerful enough to play TF2, because one of my friends has it with a GT 730. It doesn't seem to have enough CPU power to not bottleneck the card.
I may be completely wrong here, IDK. I'm hopefully going to make a tiny (only just big enough case for ITX size) build.
Another thing I saw is that it downclocks the CPU when the GPU is doing more and vice versa - which doesn't seem like a great idea if you're going to be using both at the same time - as you will be with gaming.
Sig under construction.
https://linustechtips.com/topic/355652-low-power-pc-suggestions/#findComment-4828435
Yeah, which is really unfortunate with literally the perfect mini itx system (cheap motherboard, processor, low watt power supply in a hawt case :wub: ) I think the Asus mobos allow for overclocking, so if you were to ghetto fit a really nice aftermarket cooler, this thing could probably be pushed to the extreme.
https://linustechtips.com/topic/355652-low-power-pc-suggestions/#findComment-4828458
Thanks
hmm hte gtx 750ti is pretty cheap it only uses like 60 watts
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/355652-low-power-pc-suggestions/#findComment-4828463
other than tnhat id suggest a super cheap itx 1150 board with a celeron and whatever gpu op can find cheap.
Falcon: Corsair 750D 8320at4.6ghz 1.3v | 4GB MSI Gaming R9-290 @1000/1250 | 2x8GB 2400mhz Kingston HyperX Beast | Asus ROG Crosshair V Formula | Antec H620 | Corsair RM750w | Crucial M500 240GB, Toshiba 2TB, DarkThemeMasterRace, my G3258 has an upgrade path, my fx8320 doesn't need one...total cost £840=cpu£105, board£65, ram£105, Cooler £20, GPU£200, PSU£88, SSD£75, HDD£57, case£125.
 CASE:-NZXT S340 Black, CPU:-FX8120 @4.2Ghz, COOLER:-CM Hyper 212 EVO, BOARD:-MSI 970 Gaming, RAM:-2x4gb 2400mhz Corsair Vengeance Pro, GPU: SLI EVGA GTX480's @700/1000, PSU:-Corsair CX600m, HDD:-WD green 160GB+2TB toshiba
CASE:-(probably) Cooltek U1, CPU:-G3258 @4.5ghx, COOLER:-stock(soon "MSI Dragon" AiO likely), BOARD:-MSI z87i ITX Gaming, RAM:-1x4gb 1333mhz Patriot, GPU: Asus DCU2 r9-270 OC@1000/1500mem, PSU:-Sweex 350w.., HDD:-WD Caviar Blue 640GB
CASE:-TBD, CPU:-Core2Quad QX9650 @4Ghz, COOLER:-OCZ 92mm tower thing, BOARD:-MSI p43-c51, RAM:-4x1GB 800mhz Corsair XMS2, GPU: Zotac GTX460se @800/1000, PSU:-OCZ600sxs, HDD:-WD green 160GBBlueJean-A
 CASE:-Black/Blue Sharkoon T9, CPU:-Phenom2 x4 B55 @3.6Ghz/1.4v, COOLER:-FX8320 Stock HSF, BOARD:-M5A78L-M/USB3, RAM:-4GB 1333mhz Kingston low profile at 1600mhz, GPU:-EVGA GTX285, PSU:-Antec TP550w modu, STORAGE:-240gb  M500+2TB Toshiba
CASE:-icute zl02-3g-bb, CPU:-Phenom2 X6 1055t @3.5Ghz, COOLER:-Stock, BOARD:-Asrock m3a UCC, RAM:2x2GB 1333mhz Zeppelin (thats yellow!), GPU: XFX 1GB HD6870xxx, PSU:-some 450 POS, HDD:-WD Scorpio blue 120GB
CASE:-Packard Bell iMedia X2424, Custom black/red Aerocool Xpredator fulltower, CPU's:-E5200, C2D [email protected]<script cf-hash='f9e31' type="text/javascript"> /* */</script>(so e8500), COOLER:-Scythe Big shuriken2 Rev B, BFG gtx260 sp216 OC, RAM:-tons..
Gigabyte GTX460, Gigabyte gt430,
GPU's:-GT210 1GB,  asus hd6670 1GB gddr5, XFX XXX 9600gt 512mb Alpha dog edition, few q6600's
PICTURES CASE:-CIT mars black+red, CPU:-Athlon K6 650mhz slot A, COOLER:-Stock, BOARD:-QDI Kinetiz 7a, RAM:-256+256+256MB 133mhz SDram, GPU:-inno3d geforce4 mx440 64mb, PSU:-E-Zcool 450w, STORAGE:-2x WD 40gb "black" drives,
CASE:-silver/red raidmax cobra, CPU:-Athlon64 4000+, COOLER:-BIG stock one, BOARD:-MSI something*, RAM:-(matched pair)2x1GB 400mhz ECC transcend, GPU:-ati 9800se@375core/325mem, PSU:-pfft, HDD:-2x maxtor 80gb,
PICTURES CASE:-silver/red raidmax cobra (another), CPU:-Pentium4 2.8ghz prescott, COOLER:-Artic Coolering Freezer4, BOARD:-DFI lanparty infinity 865 R2, RAM:-(matched pair)2x1GB 400mhz kingston, GPU:-ati 9550@375core/325mem, PSU:-pfft, HDD:-another 2x WD 80gb,
CASE:-ML110 G4, CPU:-xeon 4030, COOLER:-stock leaf blower, BOARD:-stock raid 771 board, RAM:-2x2GB 666mhz kingston ECC ddr2, GPU:-9400GT 1GB, PSU:-stock delta, RAID:-JMicron JMB363 card+onboard raid controller, HDD:-320gb hitachi OS, 2xMaxtor 160gb raid1, 500gb samsungSP, 160gb WD, LAPTOP:-Dell n5030, CPU:-replaced s*** cel900 with awesome C2D E8100, RAM:-2x2GB 1333mhz ddr3, HDD:-320gb, PHONE's:-LG optimus 3D (p920) on 2.3.5@300-600mhz de-clock (batteryFTW)
https://linustechtips.com/topic/355652-low-power-pc-suggestions/#findComment-4828470
Well I found a 260x for £99 which is dam good But would it Be bottled by the 5350? the i3 is like £90 which is a stupid price, maybe an a10?
https://linustechtips.com/topic/355652-low-power-pc-suggestions/#findComment-4828475
no need for a cooler, i had a 5150 (1.6ghz) ran a 125fsb so it was at 2ghz on stock volts (like 1.2 or something) with the silent cooler, was a great little platform, the gpu gets overclocked with the cpu so from 600mhz it should of been around 750mhz.
4gb stick of ram i got second hand, tried my r9-290 in it but it wouldnt let it boot, ran great with my r9-270 though.
single threaded games wont be great as its like a slow pentium dual core however even on IGPU it loved grid and bioshock infinate.
it really is a great system, i only sold it (for cost) to finance my g3258 itx rig, it cost twice as much but has twice the power...
https://linustechtips.com/topic/355652-low-power-pc-suggestions/#findComment-4828505
Intel compute on a stick would be awsome but it won't cut it for gaming.
You might be able to play an indie game but nothing more than that.
On the other side, you could wait for skylake and get one of their low power quad core cpus (rumored, this was covered in the wan show this friday).
https://linustechtips.com/topic/355652-low-power-pc-suggestions/#findComment-4828522
if you dont want to mess with a wifi dongle get this, built in wifi AC 983Mbit or something, DUAL ethernet ports.
http://www.scan.co.uk/products/msi-z87i-ac-intel-z87-mini-itx-s1150-ddr3-sata-iii-6gb-s-sata-raid-pcie-30-(x16)-dp-dvi-hdmi-wifi-ac
if you want to use aftermarket cooling for the cpu without interfering with the gpu get this, only has 2 sata ports though.
http://www.scan.co.uk/products/asus-h81i-plus-intel-h81-s-1150-ddr3-sata-iii-6gb-s-pcie-20-(x16)-d-sub-dvi-d-hdmi-mini-itx
and put this in it,
http://www.scan.co.uk/products/intel-pentium-k-g3258-lga-1150-haswell-dual-core-32ghz-clock-1100mhz-gpu-32x-ratio-cpu-retail
ive done it, and cpu was nowhere near as good as everyone makes out, its half a 4690k for 1/4 of the price which sounds great but in modern titles it bottlenecks allot with both cores pinned HOWEVER for what you're doing itll be great.
edit- tf2 isnt demanding you can do that on onboard with kabini and this.
https://linustechtips.com/topic/355652-low-power-pc-suggestions/#findComment-4828530
Intel makes low-power versions of the i3. You could pair that with a 750ti or something the like and have a great machine.
https://linustechtips.com/topic/355652-low-power-pc-suggestions/#findComment-4828597
So is it worth the £25 for the and am1 and a GPU? What's the lowest you could get away with?
Again low power and price is key
https://linustechtips.com/topic/355652-low-power-pc-suggestions/#findComment-4828627
Well the amd 5350 and a 750 ti will have an estimated tdp of 85, less than that at idle, and it's all around much cheaper.
 if you get an A8 7600, you're getting a 45w system with higher CPU performance and a great igpu that can run 3d games, and the cost for the motheroard and apu together should amount to the cost of the 750 ti,  am1  amd 5350 and mobo.
https://linustechtips.com/topic/355652-low-power-pc-suggestions/#findComment-4828795
So a8 or the CPU/GPU, Ive always wanted a 750Ti though, I think their neat little cards, just need proprietary GPU drivers for Linux
https://linustechtips.com/topic/355652-low-power-pc-suggestions/#findComment-4831367
