  • 5 months later...
no it is not normal for a card to "shake" but here are some tips
1.Is the card secured properly to the pci-e bracket using screws
2.is the cooler secured properly to the card, are there any loose parts
3. are the cooling fans chipped or are they extremely loose in their bearings ( small vertical movements up and down is normal)
but the real question is, is this an issue?, if the problem is only present when the fan is at 50% or above, and the fan never reaches 50% in games then don't worry about it. If the card rattles during games then I would suggest an RMA to sapphire, if it is annoying you badly
Also known to his peers as Lord Scrubby McScrubington
https://linustechtips.com/topic/3556-sapphire-7870-problem/#findComment-530149
