Hey I'm building a pc for programming. I work with Eclipse, Visual Basic, and I would like to learn Javascript.  I already have a
500gb seagate barracuda
8gb kinston hyper x
asus h81 motherboard.
random case and antec 500w power supply
So which Haswell cpu should I get? I think most people say to get the i5 but I don't want to spend that much money so will a G3258 be fine or something? I'm not overclocking
And should I get a ssd?
My Old Rig: Phenom II X4 965 4.0 ghz, Asus Motherboard, 4 GB DDR3-1333, Antec Case and PSU, no video card atm
My New Rig: i5-4590, MSI Motherboard, 8 GB DDR3-1600, Corsair Case, XFX PSU, HD 7950
https://linustechtips.com/topic/355459-suggestions-for-a-programming-pc-build/
Start by ditching VB it wont get you far. Other than that I would say go for an current i5 non-k and you'll have a decent system. The thing to remember is that programming is not really THAT taxing. You might want to upgrade to 16gb ram, but you'll see if you need more ram.
I dont really agree with the G3258. Cheaping out on a CPU isnt something you should do same goes for the PSU. A i5-4460 would do better along with its four cores aswell
Maybe these parts would be a good addition
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($176.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.89 @ OutletPC)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($148.89 @ OutletPC)
The Extra Cores should help run different programmes at the same time and the 840 Evo is a great ssd to choose with its high speeds.
You could add on a 80+ Gold supply for less energy and noise but its your choice
i would also go with a custom CPU cooler because sometimes while multi tasking with programmes the cpu may get quite hot
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor  ($113.98 @ OutletPC)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($43.98 @ Newegg)
Total: $157.96
Generated by PCPartPicker 2015-04-26 14:31 EDT-0400
The most i would suggest for programming.
Also some h81 mobos would need their bios to be updated to work with a haswell refresh cpu(G3258 for example) and i don't think you have a spare haswell CPU around.
Lol ok. What ide do u prefer for C++/C#
the antec is 80+ bronze so i'm sure it's half decent
  • 2 weeks later...
The core i5 is a must any lower and it will be terrible performance i have a i7 5960x but thats overkill unless you're running virtual machines in the future then get more cores and no need for gpu
My system
  • CPU
    Core i7 5960x
  • Motherboard
    Asus x99 deluxe
  • RAM
    32 gb Crucial Ballistix Sport
  • GPU
    R9 295x2
  • Case
    Corsair Vengeance C70
  • Storage
    500 gb Samsung 850 evo and 1 tb WD blue
  • PSU
    Corsair RM 1000
  • Display(s)
    LG 34UM95-P 34 X2
  • Cooling
    Custom Loop
  • Keyboard
    Corsair K95
  • Mouse
    Thermaltake Theron white
  • Sound
    Bose surround
  • Operating System
    Win 8.1
Cpu: Intel i7-5820k at 4.6 Ghz // Motherboard: Asus X99 Pro // Ram: 32gb of Crucial Balistix at 2400 Mhz // Gpu: GTX 1080 Founders Edtion // SSD: Samsung 850 evo 250gb, Samsung 950 pro 256 gb, // Cooler: Cooler Master ml240r // Case: NZXT h500i
Very late, but C++ and C# are not really similar. As fas as IDE goes C# the only way that makes sense is well - VS and for C++ I usually just use vim
CLion for C++/C. https://www.jetbrains.com/clion/?fromMenu
--Neil Hanlon
Operations Engineer
