For this kind of processor, it will be much less of a headache to get a 990FX board, such as this board, which is a great option.
However, if you're on a tight budget, I recommend getting this motherboard
PC: AMD Ryzen 5 1600 @ 3.8GHz | EVGA RTX 2060 SUPER | MSI B350 Gaming Pro Carbon | G.Skill Ripjaws V 16GB @ 3200MHz C14 | EVGA G3 650W
Laptop: 2023 Macbook Pro 16" - M2 Max | 64GB RAM | 1TB SSD
https://linustechtips.com/topic/355424-help-me-find-a-mobo/#findComment-4826130
thats what i would have suggested too (had it for 1 1/2 years worked fine) but its out of the price range at least here in austria/germany
the tax is so high on the uk on electrics
My speakers dont even fit on or under my desk...PA's FTW
https://linustechtips.com/topic/355424-help-me-find-a-mobo/#findComment-4826182
