How many CPU cores?
Go to solution Solved by minibois,
How many CPU cores do you need for gaming, and or video editing/rendering? Like some of the higher things that would take more cores - I the minimum should be about 4 but what amount shouldn't be?
Rendering usually means more=better
Gaming just wants a few fast, close to 4 four preferably.
It depends on your budget though. Low end: AMD Athlon X4 860K (a quad core CPU), mid end: i5 4690K (quad core), High end: i7 4790K (Quad core+ hyper threading), extreme end: i7 5960X (8 core + hyper threading)
This video may help:
At the moment, unless you're playing GTA V on a high end setup, you won't benefit from more than 4 cores for gaming.
Rendering will use as much power as you have so assuming you can get more of the same power cores, the more cores the better for rendering. Streaming you kinda want as many cores as you can have but you also want to have good single-core performance.
Sig under construction.
https://linustechtips.com/topic/355404-how-many-cpu-cores/#findComment-4825888
https://linustechtips.com/topic/355404-how-many-cpu-cores/#findComment-4825909
You need a bajillion cores for EVERYTHING!!!!!!!!!!
JK
But like what tedster posted is good.
Steve Wozniak - "Never trust a computer you can't throw out a window."        Carl Sagan - "If you want to make an apple pie from scratch, you must first create the universe."
CPU: Core i5 6600K Cooling: NH-D14 Motherboard: GA-Z170XP-SLI RAM: 8GB Patriot Graphics: Sapphire Nitro R9 380 4G Case: Phanteks Enthoo Pro HDD: 2TB Seagate Barracuda PSU: Threamaltake Smart 750W
My computer runs on MSX, Its very hard to catch.
https://linustechtips.com/topic/355404-how-many-cpu-cores/#findComment-4825911
I don't have a budget if I'm saving up for something that needs to get the job done :D
https://linustechtips.com/topic/355404-how-many-cpu-cores/#findComment-4825928
Well the last CPU I mentioned is 1K USD and may just be way overkill... At least for gaming, depends on what you render.
Inbetween the 4790K and the 5960X you also have the i7 5820K and i7 5930K CPU's, which are 6 core + hyper threading CPU's and they are not as expensive as the 5960X CPU.
The 4790K is just a beast CPU in per core performance
https://linustechtips.com/topic/355404-how-many-cpu-cores/#findComment-4825948
super extreme end: intel Xeon E5-2699 v3 (18 core + hyper threading)
"Never quote yourself"
        -I need a better name
https://linustechtips.com/topic/355404-how-many-cpu-cores/#findComment-4825964
super extreme end: intel Xeon 2699 v3 (18 core + hyper threading)
"super ultra extreme end: 2 of those."
LinusMediaGroup - 2015
:P I don't know a whole lot about Xeon CPU's, so I'm never comfortable recommending them
https://linustechtips.com/topic/355404-how-many-cpu-cores/#findComment-4825976
