Help deciding processor for parent
Solved by Opcode,
If she plays only one video at a time online (not three YouTube videos at once) the A4-6300 may suffice. It's about the same price as it is here in the U.S. What you'll be wanting to invest into is memory. Regardless of browser the more tabs you got going (especially Chrome) it's going to devour memory. So if you're looking to run 10+ tabs in two different browsers at the same time 4GB is an absolute minimum. A4-6300 + 4GB + SSD is where I would start. As long as you order a decent motherboard you can always upgrade the machine to a quad core later on.
