So I am having internet issues.It was working this morning this morning but now one i turned my pc back on it has limited access .
I have tested the cord and pluggin it into another pc works. The switch it is on also has another pc that currently has internet still.
When i run the diagnostic it says it could not detect proxy settings.
The system is:
asrock 970 extreme 3
8gb ram
Fx 6100
Radeon hd 7950
750w psu
Windows 8 64 bit
IP info:
http://www.anony.ws/image/kkbN
https://linustechtips.com/topic/35454-internet-problems/
Try this, Disable ipv6 on the nic and set a static IPv4. From that image you don't have an IPv4 address or a gateway.
it will look something like this
Address:192.16.0.99
Subnet:255.255.255.0
GATEWAY:192.16.0.1
DNS:8.8.8.8
DNS2:8.8.4.4
"There's no test like production!"
https://linustechtips.com/topic/35454-internet-problems/#findComment-454342
