I just had the best idea yet, turn my old hp p7-1235 into a budget gaming rig for $150. Here's the plan buy a 750ti and put in in there. What are your thoughts?
Here's the desktop specs: http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c03359127
Here's the pcpartpicker list:
Video Card: EVGA GeForce GTX 750 Ti 2GB Superclocked Video Card  ($145.99 @ Amazon)
Other: HP P7-1235 (Purchased)
Total: $145.99
Generated by PCPartPicker 2015-04-24 11:19 EDT-0400
https://linustechtips.com/topic/354245-project-budget-sleeper-pc-project-bspc/
Do it! $150 for a gaming rig is cheap!  Worst case scenario, the thing bottlenecks your new GPU slightly.
i7 4790k @4.7 | GTX 1070 Strix | Z97 Sabertooth | 32GB  DDR3 2400 mhz | Intel 750 SSD | Define R5 | Corsair K70 | Steel Series Rival | XB271, 1440p, IPS, 165hz | 5.1 Surround
PC Build
Desk Build
what do you think the resale value would be? i want to buy a 16gb kit of ram for my main pc or maybe another 970 idk
or maybe a cuadro card for an extra boost in rendering
Hard to say.  My guess is between $300 and $400.  is monitor included?
PC Build
Desk Build
i have the acer 900p monitor witch i bought with it but i use right now for editing but i can live without it
Should be able to get $400 with monitor.  look around local classified ads to see what others are selling in that price range.
PC Build
Desk Build
