I need a mATX because i travel a lot and i need it in a small shape is this build looking good?
Case:Cooler Master N200
Motherboard:Gigabyte GA-Z77MX-D3H
Processor:Intel I5 3470
CPU Cooler:Cooler Master T4
Video Card:EVGA 760 ACX Cooler
Memory:Corsair Vengeance 4x4
HD:Western Digital 1 TB
Sound Card:Asus Xonar 5.1
Power Supply:Corsair 750W
Is everything compatible in my build??
Will it run next gen games??
Any changes??
I want it to be at maximum 1400 dollars
Thanks
https://linustechtips.com/topic/35383-micro-atx-pc-build/
Corsair Obsidian Series 350D-$104.99
i5-4670K-$234.99
EVGA GeForce GTX 760 2GB-$249.99
ASUS GRYPHON Z87 -$169.99
CORSAIR Vengeance Pro 8GB (2 x 4GB)-$75.99
Corsair H100i-$99.99
WD Blue 0.5TB-$59.99
Corsair Neutron GTX 240gb-219.99
SeaSonic SS-750KM3-$134.99
https://linustechtips.com/topic/35383-micro-atx-pc-build/#findComment-453308
i5-4670K-$234.99
I think that maybe a 120gb ssd and hyper 212 evo and up to a 770?
https://linustechtips.com/topic/35383-micro-atx-pc-build/#findComment-453324
Sounds good, just remember the overclock will be smaller with that cooler
  • Cooler Master Storm Enforcer
  • I7 3770K @ Stock
  • Gigabyte Z77X-UD5H
  • AMD Radeon R9 290
  • Cooler Master Hyper 212+
  • 16gb Corsair Vengeance 1600mhz
  • 2x 1tb WD Green Drives (RAID 1)
  • 256gb Samsung 840
  • Peripherals
  • Logitech G502 Proteus Core
  • Ducky Shine 3 - Blue LED, Brown Switches
  • Samsung SyncMaster 2443
  • Custom Mousepad http://imgur.com/xJWASQM
  • Logitech G35
  • Altec Lansing Octane 7
https://linustechtips.com/topic/35383-micro-atx-pc-build/#findComment-453384
i think he should still get up 2 4.2ghz if doesnt get a terrible chip and if he get a really good OCer he could get up 2 4.6ghz with less than 80C
That may be so but it will definitely run hotter than an h100i
  • I7 3770K @ Stock
  • AMD Radeon R9 290
  • 256gb Samsung 840
  • Peripherals
  • Logitech G35
https://linustechtips.com/topic/35383-micro-atx-pc-build/#findComment-453400
For sure i would recommend checking out the ASUS GRYPHON Z87 m-atx m/board, its beast.. and the armor kit for it.
Have you also looked at the seagate hybrid drives? you can get them in 1 TB and the best of both worlds if you intend just to use one drive. (SSHD)
and to save some money, i don't think you need a seperate sound card if you get a half decent m/board they come with good onboard sound nowadays.
got to love Asus components
https://linustechtips.com/topic/35383-micro-atx-pc-build/#findComment-453493
I am thinking about finishing it like this
i5-4670K-$234.99
WD Blue 1TB
Corsair Force 3 60GB SSD
Corsair 750w Power Supply
and i`m thinking about getting a water cooler which should i take corsair h100i or h50
and i should get 16GB of memory because i also do some photo/video editing i dont only play games i should get corsair or kingston hyper x memory?
https://linustechtips.com/topic/35383-micro-atx-pc-build/#findComment-454834
A few edits/my recommendation: http://pcpartpicker.com/p/1gknq
It is sli ready.
https://linustechtips.com/topic/35383-micro-atx-pc-build/#findComment-455508
I think that that case is horrible and he likely wants a K CPU, and he doesnt need a soundcard that bad,
How the case is horrible? It's small and looks sleek imo. Also, I don't see much of a reason to get a K cpu. A 3rd or 4th gen non-K cpu has no problem pushing 2 770's in sli.
As an oveclopcker myself, it's cool but the performance difference isn't noticeable if you don't need the processing power.
The OP never mentioned their sound setup so we don't know whether or not he needs a sound card.
https://linustechtips.com/topic/35383-micro-atx-pc-build/#findComment-455541
i thinking its is going to be like this
i5-4670K-$234.99
WD Blue 1TB
 i just need to choose now which water cooler i going to take and which brand of memory and how much should i take
https://linustechtips.com/topic/35383-micro-atx-pc-build/#findComment-455547
Read the reviews on the case, I have read it`s a hit or miss for working usb ports
https://linustechtips.com/topic/35383-micro-atx-pc-build/#findComment-455646
I've read all the reviews from amazon and newegg and none have complained about usb ports not working.
The main complaint was the cable management when not using a modular psu since the case was small.
https://linustechtips.com/topic/35383-micro-atx-pc-build/#findComment-455698
Corsair H60 as cooler and 8 GB of Corsair for memory, is ok??
The brand of the ram doesn't really matter. Ram is ram.
Only get the H60 for looks and not for cooling. If you're going for an AIO cooler, don't go lower than a H80i.
https://linustechtips.com/topic/35383-micro-atx-pc-build/#findComment-455955
