It really depends to what you want. It can get really pricy too. You could look at what JayzTwoCents had before he want to x99. He had his gpu's and cpu running on seperate loops.
Also hardline or soft tube?
Whatever's cheaper but I want cpu and gpu water cooled
Does "cheaper" mean you have a budget ?
You spent 1.5k+ on the gpu's , I would not skimp and try to do a 400$ loop .
Recommend what is best, not what you preffer.
"Like" comments to show your support of them or the idea they express.
Around $1000
Here are the steps :
-choose a case ( caselabs if you want to spend a lot of $$ or other ) .
-decide if you want to go smart or overkill for your loop
Here is to help with the case choosing : https://www.youtube.com/playlist?list=PLknCNmc8uMa4w2kK5ybqLWss2tS3I2VNo
