Looks pretty much perfect for no OCing if you're gaming at 1080p or 1440p. Maybe change the case to a Cooler Master N200.
https://linustechtips.com/topic/353260-how-is-my-build/#findComment-4801106
CPU - Good
Mobo - Good
Ram - Good
SSD - Good
HDD - Good
GPU - Good, though I'd recommend the gigabyte g1 gaming, runs quieter and cooler.
Case - Good
PSU - Meh, Stick to corsair, seasonic, silverstone, or evga for power supplies, and semi-modular is perfectly fine too, as the only pre-attached cables are the 24 pin and cpu power. (I'd go for a corsair cx600m or similar)
I'd also suggest investing in a couple extra decent quality case fans and an aftermarket cpu cooler just to help keeps temps down as low as possible, not to mention the intel stock cooler can be a bit loud when it has to cool a cpu that is under a bit of stress.
https://linustechtips.com/topic/353260-how-is-my-build/#findComment-4801111
Just a few small changes.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($222.50 @ shopRBC)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard ($96.25 @ Vuugo)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($83.45 @ DirectCanada)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive ($88.98 @ DirectCanada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($63.98 @ DirectCanada)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card ($414.99 @ NCIX)
Case: Cooler Master N200 MicroATX Mid Tower Case ($49.99 @ NCIX)
Power Supply: XFX XTR 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($104.98 @ Newegg Canada)
Total: $1125.12
Generated by PCPartPicker 2015-04-22 17:46 EDT-0400
And @TheKDub that PSU is great. Its one of the most recommended PSUs in a Portuguese forum I frequent as well, for its quiet operation and reliability ;)
"an obvious supporter of privacy"
https://linustechtips.com/topic/353260-how-is-my-build/#findComment-4801145
http://ca.pcpartpicker.com/p/NC76FT
I dont plan on overclocking at all
Thanks
Fantastic. Except the graphics card. The GTX 970's video RAM is broken, don't buy it. You will be much better off with a R9 290X, which will perform pretty much the same, and will be slightly cheaper.
http://ca.pcpartpicker.com/part/asus-video-card-r9290xdc2oc4gd5
i7 4790K || R9 290X + R9 290 || 16GB G.Skill TridentX 1866 || Gigabyte Z97MX Gaming 5 || Crucial MX100 256GB || WD Caviar Blue 1TB
https://linustechtips.com/topic/353260-how-is-my-build/#findComment-4801278
if youre paying that much for a locked cpu and H97, why not just buy the 4690k and a Z97 which will probably cost the exact same or a little more, at least down the road you have the option
https://linustechtips.com/topic/353260-how-is-my-build/#findComment-4801314
CPU - Good
Mobo - Good
Ram - Good
SSD - Good
HDD - Good
Case - Good
The XFX XTR is made by Seasonic. It says XFX Though, Like how the EVGA 750B2 is Actually made by Superflower, I'll look into the Gigabyte One though, This is actually a PC that I'm building For my Brother, I already built a similar one with The G1
Thanks For The Input
 Case: Define R5 I GPU: G1 GTX 970 I CPU: i5 4690k I RAM: G.Skill Ripjaws X I PSU:  EVGA 750B2 I Cooler: Noctua NH D15
MB: ASUS Z97-A I SSD: Crucial MX100 256GB I HDD: WD Black 1TB
https://linustechtips.com/topic/353260-how-is-my-build/#findComment-4801410
