so i have 8 gb of gskill ripjaw x ram and i have the problem that my ram slowly fils up until about 7,5 of the 8 gb is in use and it only goes down if i reboot my pc.
I need to know if it is a software issue (reinstall my pc) or if it is hardware related (replace ram/motherboard)
Here are all my specs:
Os:Windows 7 enterprice 64 bit
Cpu:intel core i5 4690k
Ram:8 gb dual channel 799mz gskill ripjaw x
motherboard: gigabyte z97-hd3
Videocard: assus gtx 770
Thanks for the help
https://linustechtips.com/topic/353148-ram-problems/
Sounds like a background program has a memory leak. Check which program is using the most memory when it's filled up. (In W8.1 it's in the task manager. Idk in W7)
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/353148-ram-problems/#findComment-4799571
Definitely software issue, can't u use Resource Monitor or Task Manager to find the culprit?
https://linustechtips.com/topic/353148-ram-problems/#findComment-4799630
No need to star a new thread a day after your last one...... Did you look at the help you had there first?http://linustechtips.com/main/topic/351895-wierd-ram-propblems/#entry4784264
CPU: I5-4440 / MOBO: Gigabyte GA-Z87-DS3H / RAM: G.Skill ripjaws 2x4GB / Storage: Samsung 840 EVO 128gb SSD, 1TB WD HDD / PSU: Corsair CX500M / Case: Xigmatek Aquila / Monitor: Dell U2414H
https://linustechtips.com/topic/353148-ram-problems/#findComment-4799691
