CPU Combo for GTX 760?
Go to solution Solved by nhatduy1611,
Here you go.
CPU: Intel Core i3-4160 3.6GHz Dual-Core Processor  ($109.95 @ SuperBiiz)
Motherboard: MSI H81I Mini ITX LGA1150 Motherboard  ($62.99 @ Directron)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($29.99 @ NCIX US)
Total: $202.93
Generated by PCPartPicker 2015-04-22 11:31 EDT-0400
Well, I thought I was going for an FX 6300 on a Micro ATX platform for my GTX 760, but now I'm not so sure. The AM3+ socket is already on it's last leg, so I don't know what I want anymore. Help me find a CPU, motherboard, and PSU combo for $200 that will not bottleneck the GTX 760? There is also the option of selling my 750 Ti to get a better processor, but I don't know what it will go for (make me an offer if you're interested). Preferably the platform should be Mini ITX, but Micro ATX is okay as well.
https://linustechtips.com/topic/353045-cpu-combo-for-gtx-760/
For anyone who asks why the PSU, my current one if an OEM TFX psu with no 8 pin PCI-E power connector.
EDIT: ALSO! It has to be more than a dual core. I do a lot of multitasking while playing games, which is why Iwent for the FX 6300 initially. A G3258 will simply not do.
https://linustechtips.com/topic/353045-cpu-combo-for-gtx-760/#findComment-4798402
Here you go.
Total: $202.93
Mainboard:ROG-STRIX-B360-G-GAMING/Cpu:I5 8400 /Gpu: Galax RTX 2070 /Ram: Corsair Vengeance 16 GB DDR4/ Storage:1TB HDD 2 Corsair SSD PSU : Corsair 550W/Cooling: Silverstone Air Cooler/ / Case : Corsair/Keyboard:Razer Chroma TKL/Mouse:Mionix Castor+Steelseries Qck Mass/Headphone:V Moda M100
Quote me if you when me to reply to something.
https://linustechtips.com/topic/353045-cpu-combo-for-gtx-760/#findComment-4798449
Here you go.
Total: $202.93
Okay, I will go with this and eventually upgrade the processor.
https://linustechtips.com/topic/353045-cpu-combo-for-gtx-760/#findComment-4798455
http://pcpartpicker.com/p/shTPvK
If you can find an I5 for less than good for you. I'm running a slower I3 with an 960 and no bottle neck at all
System Spec: H87 mobo from Zotac, I3 4130, 4GB ddr3 1600mhz Cas 11, WD green 2TB all in side of a Cooler Mater Elite 120
https://linustechtips.com/topic/353045-cpu-combo-for-gtx-760/#findComment-4798490
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($64.99 @ SuperBiiz)
Motherboard: ASRock Z97M Anniversary Micro ATX LGA1150 Motherboard  ($74.99 @ Newegg)
Total: $162.47
Generated by PCPartPicker 2015-04-22 11:40 EDT-0400
edit: oops i just saw you didnt want G3258
https://linustechtips.com/topic/353045-cpu-combo-for-gtx-760/#findComment-4798521
Total: $162.47
No problem I am going with an i3 4150.
https://linustechtips.com/topic/353045-cpu-combo-for-gtx-760/#findComment-4798619
