So my friend has put together a build for himself.
His budget is $1000 AUD but can go slightly over and will be mainly used for gaming.
This doesn't include perphirals, monitors or OS
His current build plan is:
CPU: i5 4460                                                        = $259
GPU : Galax GTX 960                                          =$299
MOBO: MSI A87M-E35                                        =$75
HDD: Seagate Barracuda 1TB                             =$75
SSD: Kingston HyperX Fury 120GB                     =$85
PSU: Corsair CX-500 V3                                     =$89
RAM: Kingston HyperX Fury 2x4GB 1866hz       =$99
CASE: Deepcool Tesseract.                                =$49
FAN: CoolerMaster S12  Silent 4 pack               =$19
I can see some things that could be changed, but what changes/opinions do you guys have?
Thanks
Mate
https://linustechtips.com/topic/352276-need-help-with-friends-pc-build/
is that a H87 board?
A is used for the AMD chipsets like A88X, A78 etc
what is the price of the R9 280X in Auzzy?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
If your at that price range the R9 290X is on sale, much better than the GTX 960, and cheaper.
http://pcpartpicker.com/parts/pricedrop/#dg_9
not in aus
can't believe i didn't see that, he had an amd cpu then just changed so I couldn't differentiate it Thanks for pointing that out. The 280x is $350 atm
Mate
CPU: i5 4460                                                        = $259
Thanks
Please get the cx500m, you build will look a lot nicer with only the needed cables
not in aus
how about the R9 280?
beats playing with just 2GB of VRAM vs the 3GB on the R9 280
the 280 is $280 hahaah legit not even punning you
grab that
it better than the GTX960
https://pcpartpicker.com/user/stevepauls4045/saved/#view=THxCmG
heres your build! i personally hand pick them all for you
wish i could help and also you blew much your money in a 960 in a similar performance as the $200 960
but heres a super better build $770(US) = $1000 (AU)
AUD as in from australian retailers, we can't get prices that cheap down here
Mate
