First Build
Solved by Happypap55,
If you're serious about editing, more cores help but if you want it mostly for gaming then you should probably go for Intel. This is what I put together based on what you want and your price point:
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($97.46 @ Amazon)
Motherboard: ASRock 980DE3/U3S3 ATX AM3+ Motherboard ($53.98 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($49.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($52.49 @ OutletPC)
Video Card: XFX Radeon R9 280X 3GB Double Dissipation Video Card ($189.99 @ Newegg)
Case: Azza SIRIUS ATX Mid Tower Case ($40.98 @ Newegg)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($64.99 @ NCIX US)
Total: $549.88
Generated by PCPartPicker 2015-04-21 01:14 EDT-0400
